layonnn previously said:
FJfunjunkie, did you install the snorkel to the CAI the same way that Shadow did? With the pvc and that rubber fitting?
No, its so much easier to install the snork and it's tube into the CAI straight in then use clear RTV caulking to seal it up. You cant start it for at least 12 hours after though. MudLoving tried the rubber fitting route and it kinda shifted the CAI box which kinda sux if you are gonna fit a battery in the other space. Just make sure you caulk the tube on the outer fender side before you put the inner fender skin on or you will be buying another set of clips to do it later if you really want a good seal. BTW they are hella cheap at cragen auto parts, you get a box of em for a couple bucks as opposed to 2.99 each at toyota. I had a post awhile ago with the size. PM me if you need the info, I'll check the garage tomorrow.
