Re: Gas Mialage, clean your MAF sensor
Jerry previously said:
Is it obvious what/where the MAF sensor is when you pull the air filter?
You won't have to pull the air filter. The MAF is downstream in the air inlet tube. You'll lift up the fancy plastic engine cover on top and see the MAF with two screws and a connector. Use the search function and then look in Uphill's thread for pictures
Jim
'05 4Runner V6 4x4
Hannah sliders, Downey skid plate, Downey coilovers, Deaver rear springs 30%/2.5", Donahoe rear shocks, rear diff breather mod, Garmin 276C GPS, LT265/75/R16 Bridgestone Revo's, Dual Batteries, Engel fridge/Two-Zone, All-Pro Ultimate LCAs, All-Pro LCA skids, Total Chaos A-Arm skids, cyclone air pre-filter, All-Phase rear diff skid. Next --> ARB rear locker!
