Old 05-13-2008, 12:08 PM   #5 (permalink)
Tubig
Tubig's Avatar
Member Number: 6452
Send a message via AIM to Tubig
Re: OEM Auxiliary Lights on the TT Edition
DominicG previously said: View Post
Easy.
Tear out the wiring loom for the lights, then:
Buy a switch (preferably a 3 prong switch).
Wire power to the switch, ground the switch, then wire the power from the switch to the lights.*
*This way is somewhat risky since you have no relay, but i use mine every night without a relay.
Thats what I did for the first 10 months since I had no clue about using relays. Finally when I got more lights, I did some searching and now have everything wired with relays.
Using a relay allows you to run smaller gauge wire to the switch inside the cabin. Basically how I understood it, the relay is a switch that is triggered by another switch usually inside the cabin.
Tubig is offline   Reply With Quote
