Re: Went to install hitch...problem. Help!
May be you could use a stubby open end wrench close end tie to a wire hanger open end first through the opening on the frame and push it in to the bolt that is spinning and hope it will catch once it catches little turn would push the hanle against the frame and hopefully work good luck.
