Re: Extending brake line and relocating bracket on rear control arms?
I noticed that happening, too, when I replaced both upper and lower rear links. I had the cross-link bar disconnected to install the upper links, and the axle really dropped quite a bit; that's when I noticed the brake lines being tight.
I wouldn't think it would be a serious problem for the occasional flex (as the rubber takes up some slack) but if flexing a lot of times, and with the rubber lines getting more brittle with age, it could be a problem...
'08 Titanium 4X4; AT; LD; A-Trac; Uniden PC78XLT CB radio & K40 hatch-mounted whip; Yaesu FT-7800R dual-band HAM radio & Comet SSB2 hatch-mounted 1/4 wave antenna; Toyota extra horn mod; no mud flaps; LT285/70/R17 Hankook Dynapro MT tars; 3" Lift (OME 884 front coils & N140S shocks, ToyTech Medium rear coils, OME N71E rear shocks); All-Phase rear diff skid; SCUBA breather mod; Steel sway bar collars; All-Pro rear shock skids and lower link skids; Digger upper and lower rear links; Rasta4x4 skids; Toytec 1" diff drop kit (as soon as I get around to spacing the skids); Metal Tech step sliders; Mini-Me OEM roof rack; fender-mounted disruptors
