Old 05-14-2008, 01:39 PM   #4 (permalink)
oscarr
oscarr's Avatar
Member Number: 7997
Re: Extending brake line and relocating bracket on rear control arms?
JoeUser previously said: View Post
I noticed that happening, too, when I replaced both upper and lower rear links. I had the cross-link bar disconnected to install the upper links, and the axle really dropped quite a bit; that's when I noticed the brake lines being tight.
I wouldn't think it would be a serious problem for the occasional flex (as the rubber takes up some slack) but if flexing a lot of times, and with the rubber lines getting more brittle with age, it could be a problem...
thats good Im not the only one with this concern.Who has stainless steel lines?What is your take on them? Please share.
ARB Bumper*OME Heavies*3" Skyjacker rear*Stock Steelies*Nittos Terras 295/70/17*Gobi Ladder*Cobra CB*AP Rock Sliders*Black Bezel*Real Wheels Light Bar*K&N Filter*Choped Body Mounts*Parrot Blue Tooth*Eliminated rear Sway Bar.
oscarr is offline   Reply With Quote
