Old 05-15-2008, 04:01 PM   #87 (permalink)
CORYRSNOWMAN
CORYRSNOWMAN's Avatar
Member Number: 19043
Re: CLEAN 12v Fuse Block Accessory Install w/Pics
Looks great. One thing though, I am an electrician and if you are going to go with a 60 amp fuse you should probably up grade to #6 awg wire which is good for about 50 amps. #10 awg wire is only rated for 30amps. more than likely it wont be an issue., but you know "what if"?
08' brick fully loaded minus off road package w/ daystar 2 1/2" leveling, 285/65rX18 Nitto Terra Grapplers on 18X9 KMC XD Diesels, dice ipod mod. Aux marine fuse block. rack mounted rear floods.
CORYRSNOWMAN is offline   Reply With Quote
