Here is an ongoing list of known existing TSB's (Technical Service Bulletins) for the'07 and '08 FJ Cruiser.
If you know of any TSB's, please post the TSB number, a brief description of the problem/fix and any links that detail the TSB in this thread. They will be added to this continually-updated list. Thanks.
And, if you see a TSB that applies to a problem that you're having with your FJ, contact your dealership with the TSB number for more details.
BR8005 - Front brake noise while in reverse.
Brake Noise When In Reverse
DL003-07 - Front and rear differential gear oil specification change.
Differential Gear OIL *TSB*
EG050-07 - Oil leak from front timing cover.
BO007-07 - Access door water leak.
NV001-07 - Inside door handle creak.
AX006-06 - Roof rack rattle noise.
AX002-07 - Gap Between Front Bumper Fascia and Skid Plate (Skid plate shim kit).
06V235000 (Recall) - Tire Inspection/Replacement.
AU002-06 - Poor sound quality for satellite radio.
PA003-07 - Paint-Colors/Scratch resistance & anti-acid paints.
AU004-07 - Audio system-Noise when using an external device.
