Old 05-17-2008, 09:20 AM   #67 (permalink)
ocr14a
ocr14a's Avatar
Member Number: 18664
Send a message via MSN to ocr14a
Re: FJ Tire Size Selection Tool
UPDATED 20080611 = Please also make sure to see this post.
I suspect my info is not at all helpful at this point (no lift), but I figured I'd add it to the list just in case other no-lifters are interested.
I will eventually lift, but it's a ways off; simply for financial reasons.
Since I knew I would only be able to do either a lift or new rims/tires now and then do the other one of those two options in a couple years, I figured the later meant more sense....i.e. if I had gotten a list now, Sandi would only have the flat-tread street tires for the first couple years, and that was just not going to work for me.
1. no lift yet
2. none
3. BFG A/T TA KO 265/75R16)
4. 16" (duh) MB V-Drives with 0 offset.
5. No
6. No*
7.
*Actually, there is a very tiny rub on the black plastic covering, but not enough to even push it back to touch the metal of the body mount when it does happen. Even with some pretty extreme offroading, declines, bouncing, flexing, it's no problem.
steven
222: "Hey Steven, what's up with your signature?"
14a: "Ah...you know me."
ocr14a is offline   Reply With Quote
