Re: will Engel 16 qt fridge fit behind psngr seat?
well I purchased the 15 quart engel. It fits behind the seat fine, but the interior storage volume is just too small. It also is loud too 45 db vs 36 for the larger units. But it gets very cold if you put it on max (-5F) and only uses 3.7 amps or so at max. At fridge temp it would use much less duty cycle so the average current draw would be probably 2 amps.
Because it is so small I am going to return it and explore other options. I think I need to examine removing the rear seats to allow install of a larger expedition worthy unit.
THe engel products are clearly of very high quality. But the 15 qt one is just too small inside for me
