Old 05-18-2008, 04:35 PM   #9 (permalink)
kcfunke
Member Number: 2202
Re: will Engel 16 qt fridge fit behind psngr seat?
White Rim,
Sorry it did not work out for you.
If I am remember correctly, the Engel/ARB 34 and 45 have the same footprint size.
For that reason, I went with the 45 and have not regretted it. I chose the ARB over Engel, just for the convenience of having an integrated themometer.
The average draw on my 45 is 2.2 amps on setting number 1, which keeps fridge temp between 35 and 38 degrees.
Of course, the more you have in it, the less the fridge runs once everything levels out.
I run mine in my rig 24/7 and can go two to three days without having to start the rig using the oem battery as long as outside temps stay below 100 degrees. When it's over 100, I need to start it once per day.
I just put an Odyssey 1700MJT in today, so I will need to experiment some to see how much actual run time I get from it, but I expect around the same.
kcfunke is offline   Reply With Quote
