Thread: Body mount chop
Old 05-21-2008, 10:06 AM   #8 (permalink)
LT.
LT.'s Avatar
Member Number: 6786
Re: Body mount chop
FdriverJ previously said: View Post
i have 33x13.5x18 on my fj. It has a 3" lift kit and spacers. I have alot of rubbing. Will the chop get the job done for me or do you guys think i will still rub. Thanks
Sounds like you will need the body mount chop. The purpose of the body mount chop is for this exact problem and others have had. With bigger tires and at full crank on the steering the tires begin to rub the body mount pretty bad. This little modification allows for full range of the steering motion with any rubbing issues.
'76 FJ40 running on Propane.
1964 FJ45LV, 6.0L Vortec, 700r4, FJ62 split case, FJ62 axles, Power Steering, Spring Over, 35s, OD green.
Metal Tech
LT. is offline   Reply With Quote
