Re: All Pro Air Dam INSTALLED!
Great install, but if you leave the outer bolts loose, then you just need to push down a bit to slide the center support bolts in & then tighten all when they are in the proper holes. If you tighten the outers before installing the center support bolts its near impossible to bend the support down enough to get the holes to line up as you experienced. Its also great to see different lights can be used, we never intended to lock everyone into 1 option. We just needed something to fab off of and the SolTeks were a very high quality mid-priced light that looks great and could be upgraded to HID later if desired.
