2ntense previously said:
Can anyone tell me why the right rear would be much higher than the left rear? I have the complete rear set up from All-Pro.
Thanks
Bryan
Please check and make sure the coils are seated properly, if they are then try and snap a couple of digital pictures and send them to us to take a look at whats going on -
terry@allprooffroad.com
Ratfink is correct also that the drivers side will sit lower typically even on stock vehicles due to extra weight from the gas tank & battery being installed on that side & nothing to counterbalance it on the passenger side. My FJ was 1/2" low from the factory on the drivers side since day 1 - it was lifted with an OME lift a week after getting it and still sat the same, just higher. When the coilovers in front were installed a lot of the lean can be adjusted out.
