Go Back   Toyota FJ Cruiser Forum > Supporting Vendors > All Pro Off Road
All Pro Off Road All Pro Off Road is a supporting vendor of FJCruiserForums.com!
Old 07-25-2007, 08:57 AM   #1 (permalink)
VooDoo FJ's Avatar
Member Number: 8218
High Clearance Tail Pipe
How much does the high clearance tail pipe change the exhaust note?
2007 FJ MT6||OME 885/895||Firestone Destination 285's||K&N Air Filter||OEM Rock Rails||All-Pro Extreme LCA's, Trailing Link Skids, High Clearance Exhaust||TRD Quick Shifter||Demello Hi-Lift Mount
TLCA #18077
N.C. Beach Buggy Assoc. #12893
TTORA #13074
NRA #149022131
VooDoo FJ is offline
Old 07-25-2007, 09:35 AM   #2 (permalink)
Member Number: 1862
Re: High Clearance Tail Pipe
i'll let you know soon...mine is being replaced as we speak. I have the TRD exhaust.
JROD - Oakley Factory Pilot
Now
07 CLS63 AMG
07 S2000 Laguna Blue
07 FJ Cruiser 4x4 VooDoo
56 Chevy Bel Air
08 Audi R8 on order
Then
06 911 S Cab
05 TECHART Boxster S Atlas Grey
06 Charger SRT8
06 Magnum SRT8
05 Prius Silver
06 300 C "PIMP JUICE"
04 S2000 Mugenized
06 Ridgeline RTL R/S
05 Accord EX
04 Accord EX
03 G35 Coupe 6MT
03 Benz CLK
02 S2000
99 Boxster
FJrod is offline
Old 07-27-2007, 09:36 AM   #3 (permalink)
RocKrawler's Avatar
Member Number: 3158
It doesnt change it much, it exits down instead of back at an angle so the reflected sound off the ground, some people can tell the difference, some cant.
I noticed a bigger difference re-routing the crossover tube behind the transfer case myself, because the tubing became 2.25" consistent between the cat & Y-pipe. It seemed to get a tad louder and felt like a little extra power at the same time (The stock tubing changes diameters a few times on the factory pipe, cant be good for flow... ).
When I installed my Flowmaster 40 series, THAT made the big difference in sound, and the tailpipe seemed to amplify that with ground reflection more than the stock exhaust note. Now it sounds pissed off when you stomp the gas pedal.
RocKrawler is offline
Old 08-11-2007, 01:29 PM   #4 (permalink)
VooDoo FJ's Avatar
Member Number: 8218
Do you have any pics of your flowmaster? I was thinking of maybe a 50 series because I don't want it super loud. What size and offset do we need?
TLCA #18077
TTORA #13074
NRA #149022131
Old 08-12-2007, 12:08 AM   #5 (permalink)
RocKrawler's Avatar
Member Number: 3158
There are a bunch of threads with the part number - I believe its a 2.25" in/out with offset inlet, centered out IIRC
