Go Back   Toyota FJ Cruiser Forum > Supporting Vendors > All Pro Off Road
All Pro Off Road All Pro Off Road
Old 09-13-2007, 10:33 PM   #21 (permalink)
SoloSK71's Avatar
Member Number: 12298
Location: Somewhere in the woods of Northern Alberta, Canada
Re: NEW PRODUCT: Ultimate Sway Bar Links
uphill previously said: View Post
I can't speak for All Pro but some of us have looked at the limiting strap option with a disconnect for trail use and it's a bit of a pain. It's different if you have a long travel solution with the limiting strap integral to the racing suspension...but for stock, it didn't seem worth the hassle.
What he said. Disconnects just do not look like an easy (or safe) option on this vehicle.
- SK
2007 Toyota FJ Cruiser ... and some mods.
You are just jealous because the voices only talk to me!
When Solomon Kane went forth again no man knew his road.
treadlightly!
SoloSK71 is offline
Old 09-13-2007, 10:34 PM   #22 (permalink)
cruiserlarry's Avatar
Member Number: 2011
These are a great upgrade for anyone who wheels with the sway bar connected (most of us)...I've seen the factory mount break, and it takes out the CV boot - which means replacement cv shafts if dirt gets in (it will).
An inexpensive way to protect against an expensive repair...
Nice work , Terry...
TLCA #9632
cruiserlarry is offline
Old 09-13-2007, 10:44 PM   #23 (permalink)
OnTheRocks's Avatar
Member Number: 407
Exactly! I even designed a fairly nice strap & disconnect, but it flexed and I never really trusted it. I did not find the articlation considerably better either - not like on a TJ or something.
TERRY!!! I sent you a PM. Please do not sell all these without putting a set aside for me. I have an early AM meeting but will call afterwards. My card should be on file. Them are some freshy units!!!!
OnTheRocks is offline
Old 09-13-2007, 10:44 PM   #24 (permalink)
RocKrawler's Avatar
Member Number: 3158
Keep in mind that the extra droop you would get with the sway bar disconected will increase your CV angle and letting the bellows on the boot rub - endangering both your CV joints and boots, neither of which is a pleasant item to replace. Disconnects have a great effect on solid axle vehicles, not so on IFS trucks. When a solid axle truck compresses up on one side the leverage effect forces the opposite side down, increasing its traction & thus having the sway bar restricts this flex. On IFS suspensions if the one side is coming up, the opposite side is just hanging there & isnt being forced down in contact with the terrain you are trying to get traction on, usually just letting the wheel spin, so it wnt do you any good, it will just increase wear on those expensive CV joints & boots from too much droop.
RocKrawler is offline
Old 09-13-2007, 10:52 PM   #25 (permalink)
SoloSK71's Avatar
I should be calling on Monday or Tuesday depending on when AirCanada gets me back someplace with a phone I can recognize and if I can remember where I hid my credit card. If I can figure out of this is a good thing or not needed with the Long Travel suspension.
- SK
treadlightly!
SoloSK71 is offline
Old 09-13-2007, 10:53 PM   #26 (permalink)
AceTechno's Avatar
Member Number: 4098
I forgot to ask. Does this work on 2WD models as well?
PERFORMANCE: Airaid intake, Gibson Exhaust, Royal Purple Oils
LIFT KIT: Toytec/Donahoe Racing 3", Spidertrax spacers
EXTERIOR: Rear Tail lite Guards, GoodYear MT tires, AP Sliders, PIAA Headlights/dome lites, Fourtrex, Hi-lift
COLOR: Voodoo Blue 4x2
AUDIO: Dice iPod interface
INTERIOR: ScanGuage II, Ellis Design Black Handles & Battery Clamp. Littlelite 12" map light W/ Dimmer.
My Build: http://www.fjcruiserforums.com/forum...shockwave.html
AceTechno is offline
Old 09-13-2007, 10:58 PM   #27 (permalink)
MudLovingFJ's Avatar
Member Number: 8945
Send a message via AIM to MudLovingFJ
they will work on the 2wd models as well i believe
The So-Cal Safari Snorkel Install Guy 7 chicken necks installed to date
MudLovingFJ is offline
Old 09-14-2007, 01:29 AM   #28 (permalink)
tisilverFJ's Avatar
Member Number: 1394
I would like a set for the rear also. It would be great if you could make them adjustable. The stock ones limit my travel.
TLCA#16292
Toytec custom coil lift,SS brake lines. PM me for Discountshttp://www.toyteclifts.com/fjcruiser...ruiserliftkits
All Phase Offroad diff skid,engine skid,Hi-Lift mount,axe/shovel mount,HD LCA frame mounts.
Spidertrax spacers.
All-Pro HD LCA's,Bandi mount.
FabFours front bumper w/PIAA lights
Stock Toyota steel wheels with 35" MTZ's.Gas/water cans mounted to stock rack. Midland hand-held CB. Thule fairing. OEM rock rails. A-Trac/Locker hack.
tisilverFJ is offline
Old 09-14-2007, 06:58 AM   #29 (permalink)
bandi's Avatar
Member Number: 2261
FarmersFight previously said: View Post
Why did you develop links instead of a disconnect system?
Just curious about this because they look good and beefy but I don't wheel with my swaybar on as I assume most people who really wheel wouldn't to acheive the extra flex.
Just to add a little, There is NO WAY to make a
disconnect system for the FJ by using the stock
bar and having disconnectable links, the design
tolerances within the CV, knuckle, LCA's, Etc.
area is too tight... That being SAID !!...
Terry... VERY NICE LINKS and great insurance
for those who flex their rigs !!!... Thank You !!...
The "Bandi Mount" Now By ALL-PRO OFF-ROAD
Phone:951-658-7077-Fax:951-658-2375-Email
bandi is offline
Old 09-14-2007, 07:08 AM   #30 (permalink)
RocKrawler's Avatar
Member Number: 3158
tisilverFJ previously said: View Post
We will have them for the rear soon, along with a relocation bracket option that will correct the link angle!
