Go Back   Toyota FJ Cruiser Forum > Supporting Vendors > All Pro Off Road
All Pro Off Road All Pro Off Road is a supporting vendor of FJCruiserForums.com!
Old 10-09-2007, 03:27 PM   #1 (permalink)
RocKrawler's Avatar
Member Number: 3158
Bilstein Low Cost Front Lift!
Bilstein now offers a height adjustable front shock that re-uses your factory coils and gives you up to 2.5" of lift for only $99 each! All Pro has these in stock and ready for immediate delivery, call and order yours now.
Bilsteins Promo material states:
Bilstein announces a new offering of height adjustable 5100 Series replacement shocks for
coilover design front suspension pickups. These new coilover style shocks utilize the vehicle’s
existing stock coil spring, with applications available for the 2004-06 Toyota Tundra and
Tacoma (AND FJ!), Ford F-150 and soon to include the Nissan Titan.
An extremely simple and affordable alternative to much higher priced systems, these new
5100 Height Adjustable shocks feature multiple snap-ring grooves on the body of the shock
to accommodate different spring seat positions, allowing height adjustments from 0" to 2.5",
depending on the application. By raising the spring seat position, you can alter the factory
rake to achieve a level front to rear ride height while accommodating up to 33" diameter tires.
The shocks feature vehicle specific split digressive valving and Bilstein’s industry leading high
gas pressure monotube technology.
As with all 5100 series shocks, these new height adjustable shocks provide superior
performance characteristics, feature bright Zinc plated bodies and come with a lifetime
aftermarket warranty. Bilstein also offers companion rear 5100 shocks with matched valving.
Bilstein designs and manufactures shocks for most cars, trucks and SUVs.
RocKrawler is offline
Old 10-09-2007, 04:26 PM   #2 (permalink)
stringmachine's Avatar
Member Number: 7766
Re: Bilstein Low Cost Front Lift!
now this looks like a great new thing.. is there a website for installing these? I wonder orginally , looks like you still have to unseat the ome springs? cool idea.
stringmachine is offline
Old 10-10-2007, 07:16 AM   #3 (permalink)
RocKrawler's Avatar
Member Number: 3158
Even cheaper - this shock uses a stock spring so you dont have to buy OME's - you just:
  1. Remove your stock front shocks
  2. Remove the top coil hat from your stock shock
  3. Pull off the stock spring,
  4. Put the c-clip in the position you want on the Bilstein shock body
  5. Slide over the Bilstein supplied spring seat to lock the c-clip in place and support the coil
  6. Compress the coil and install the spring hat
  7. Bolt it into the vehicle
You're done, enjoy your new front lift for under $200! To make it even better we have a blowout sale going right now for rear 2" coil spacers from DayStar for only $59!
Old 10-10-2007, 07:31 AM   #4 (permalink)
yoda's Avatar
Member Number: 2584
I'm guessing you can use these with the OME 884 coils ?
07 FJ, At ,Upgrade #2,Toytec 1/2 FR Spacer,Auto Vent Shades,285/75/R16 Dick Cepek FC-11's on 16x8 Ultra 50/51's
yoda is offline
Old 10-10-2007, 09:20 AM   #5 (permalink)
shane4x4's Avatar
Member Number: 5342
EDIT: You cant pimp other peoples products in this vendors thread!
'07 TRD w/3" Toytec, Ellis Precision grab handles, WAAG XS Rack Insert, Over The Top HDPE Skids
TLCA#18775
Lead Run Planner: http://15ers4x4.com | Webservant: http://coloradofjs.com | Off-Road Trails Wiki: http://www.dirtopia.com
KC0KWO on 2m @ 146.520mHZ
http://www.fjc-mag.com | July Issue: http://fjc-mag.com/july-2008/july-20...issue-3-2.html
2008 Stanley Cup Champion DETROIT RED WINGS!
shane4x4 is offline
Old 10-10-2007, 09:41 AM   #6 (permalink)
SonicFJ's Avatar
Member Number: 6368
Shane4x4
This is in the vendor section. While your post might be most welcome in the general discussion area, I doubt that it is proper here.
SonicFJ
SonicFJ is offline
Old 10-10-2007, 09:47 AM   #7 (permalink)
mtrent3450's Avatar
Member Number: 10303
Dont flame me on this question. My FJ came with a revtek spacer lift( I know what you are saying) I added a front bumper with winch and it droped down about an inch to inch and a half. Can I use these in conjunction with the spacer lift to get the height back? I know better coil overs are the way to go but that is not an option at this time.
mtrent3450 is offline
Old 10-10-2007, 10:17 AM   #8 (permalink)
jeshua's Avatar
Member Number: 6888
mtrent3450 previously said: View Post
With these you can ditch the spacers all together most likely. not positive on having both but I would think you could.
Mike Ambs
www.corva.org
- Thomas Paine
Aequitas - Veritas
jeshua is offline
Old 10-10-2007, 11:14 AM   #9 (permalink)
thugasaur's Avatar
Member Number: 691
Send a message via AIM to thugasaur Send a message via Yahoo to thugasaur
i aw the 5100's at the pomona off road expo they looked nice the c collar looks like a snazzy idea im actually thinking of getting a set of these they gotta be better than tokico stock shocks
Chefj's Little known facts: Thugasaur tracked down, strangled, and gutted the Snuggle fabric softener bear because he once had a towel that was...well...not so soft.
UBFM member #00 enforcer
"Church" V2.0
2007 Voodoo 5AT 4x4
______________________
AFE cai , kenwood excelon 889 , xm2go, piaa extreme super whites , demello front skid plate and rock rails and aero flow lens covers (THANKS GUYS!) , all-pro front sway bar links
thugasaur is offline
Old 10-10-2007, 11:29 AM   #10 (permalink)
RoseCityCzar's Avatar
Member Number: 12511
Rockrawler I see your a sponsored vendor yet I cannot find a link to your business. Can you post one????
RoseCityCzar is online now
