Go Back   Toyota FJ Cruiser Forum > Supporting Vendors > All Pro Off Road
All Pro Off Road All Pro Off Road is a supporting vendor of FJCruiserForums.com!
Old 11-06-2007, 11:19 PM   #1 (permalink)
merlinridesagain's Avatar
Member Number: 6952
Anyone installed the All Pro High clearance exhaust with a WARN rear bumper
Just tried to install the high clearance exhaust with my existing WARN rear bumper and have a problem to solve. First I have to say the exhaust is very nice and will definitely avoid the crushing experience the stock exhaust met with.
The problem I have is that the frame mount cannot mount flush with the frame as the WARN mounting bracket blocks it. I'm probably going to have to come up with offset brackets or something.
Anyone else solved this problem already?
Build Up Notes
merlinridesagain is offline
Old 11-07-2007, 01:07 PM   #2 (permalink)
RocKrawler's Avatar
Member Number: 3158
Re: Anyone installed the All Pro High clearance exhaust with a WARN rear bumper
We have never tried it with a Warn bumper so keep us posted on how the install goes.
RocKrawler is offline
Old 11-24-2007, 12:32 AM   #3 (permalink)
Member Number: 6952
It took me a little while to get around to mounting the rubber exhaust mount, but here it is.
The WARN bumper attaches to the frame rails with brackets. This is the left side:
As the bracket was in the way and the original All Pro mount can't fit with the bracket in place I decided I'd make a metal strap to wrap around the rail and then an offset strip to get the rubber mount positioned correctly. This is bolted to the frame rail in the existing frame nut:
Slightly different view:
It's not the neatest, but it does the job. Things like this make me want to learn how to fabricate/weld a nice plate mount...
Build Up Notes
