Go Back   Toyota FJ Cruiser Forum > Supporting Vendors > All Pro Off Road
All Pro Off Road All Pro Off Road
Old 05-14-2008, 10:45 PM   #21 (permalink)
bankerkys's Avatar
Member Number: 9665
Re: Advice for adjusting Walker Evans Height
Right now, I am at about 38.5" from the ground to the fender well. What is the most anyone has gone? I am wonder if I could get another inch.
07 FJ TRD: 2 sets of JL Audio 6 1/2 components; 2 4" JL Audio dash speaks; 4 8" JL Audio woofs w/custom-built boxes; Rockford Fosgate subamp; Alphasonik 4 channel amp; Kenwood rear cam; Panasonic headunit; 5 farad Soundstream cap; Cobra remote radar; Magellan nav; custom seatcovers; blue dash lighting; Prestige alarm; Walker Evans Racing coilovers + rears; All-Pro Offroad a-arms; Injen intake; rock rails; hitch, & skid plate; ProComp wheels, powder-coated, w/ Cooper 285x70x17s; & more to come.
bankerkys is offline
Old 05-14-2008, 11:06 PM   #22 (permalink)
frogeye's Avatar
Member Number: 6849
bankerkys previously said: View Post
I would adjust it to the height that looks level with the rear and so that your front half shafts are not at an excessive droop while at rest (as it sits on flat ground). Even if the front is slightly lower, I feel this is better as long as you keep the front half shafts from being at a constant excessive droop.
I have found through experience that adding too much lift will cause excessive wear on the top inner front differential seals causing them to fail prematurely (this is the theory).
I've got mine at about 2.6 inches of lift and the half shafts droop about 3degrees or so at a resting stance.
I used to run mine at 3.1 inches or so and that is where I was going through seals. This could have been to a faster driving style mixed with some rock crawling.
When you compress any spring too much it takes away from the overall performance of the shock and how it cycles. This causes the suspension to always be at a droop and top out (fully extend) too fast.
I'm very happy with the WEs now that I have found their sweet spot and how to properly set them up for my truck.
Hope this helps.
Chris | My FJ El Froggo
www.frogeyesprite.org
Save The Cactus!!!
frogeye is offline
Old 05-26-2008, 12:45 PM   #23 (permalink)
crestwood36's Avatar
Member Number: 17104
Send a message via AIM to crestwood36
So I finally got around to taking care of this today. Traveling for a living sucks some times.
Frogeye, is your measurement of 2.6" the distance from the top of the threads to the top of the adjustment collar?
"The ultimate goal of the educational system is to shift to the individual the burden of pursing his own education. This will not be a widely shared pursuit until we get over our odd conviction that education is what goes on in school buildings and nowhere else."
John W. Gardner
crestwood36 is offline
Old 05-26-2008, 05:24 PM   #24 (permalink)
frogeye's Avatar
Member Number: 6849
crestwood36 previously said: View Post
Negative sir that's a guess
I don't measure from the top of the threads to the top of the adjustment collar because that is inaccurate.
I compare the measurements before adding lift the the measurements after. Just subtract the prelift amount from the lift amout for an idea of how much lift you added.
The 2.6 inches of lift is a guess. And since I raised it another 1/4 inch I'm going to guess that my front is lifted about 2.8 inches or so.
hth
Save The Cactus!!!
frogeye is offline
Old 05-28-2008, 09:47 AM   #25 (permalink)
RocKrawler's Avatar
Member Number: 3158
Mine is 39 1/8" from ground to bottom lip of front fender flare with a 35x12.5R17 BFG MT KM2 tire. Its about max height
RocKrawler is offline
Old 05-28-2008, 10:05 AM   #26 (permalink)
FJ FunJunkie's Avatar
Member Number: 7470
If the threads on most coilovers are the same, a half inch of movement should yeild about an inch of lift. now fine adjustment after that is all on you and your rig setup.
I was worried about using a spray lube on mine, do you think it will promote slippage back down again after some good trails? Just wondering because the spring will be twisting upon each compression I'd assume.
Ligten up, it's the internet!
Quote from: BigDouggieDoug
You Should Help Chris Walk
FJ FunJunkie is offline
Old 05-28-2008, 10:32 AM   #27 (permalink)
jeshua's Avatar
Member Number: 6888
I just found a typo. It said, "fool droop." WTH? Draggo are you messing with me? I know I typed, "full droop." That's a really weird homophone to mess up. Here you go Jeshua
Just saw this thread and laughed when I saw this, you know me to well froggy.
I didn't know they had a name for how stupid the English language is.
Homophone sounded like something else when i first read it.
Mike Ambs
www.corva.org
- Thomas Paine
Aequitas - Veritas
jeshua is offline
Old 05-29-2008, 08:11 AM   #28 (permalink)
frogeye's Avatar
Member Number: 6849
Talking Re: Advice for adjusting Walker Evans Height
FJ FunJunkie previously said: View Post
Junk, I mark my adjustment ring with a notch so that I count turns and monitor for any movement. Try to notch your adjustment ring (paint, sharpie, or I just scratched it with a blade.)
You know I love you man In a "bromance" kind of way. It took you long enough to spot that one.
Save The Cactus!!!
frogeye is offline
