5280FJ previously said:
For specific needs this is great, but no info on once you beef up the axles, what stress you get on the drive line all the way back to the piston rings... Info on clutch plates, etc?
Axles aren't like engines in terms of modification; mainly b/c they are "downstream" in the power flow. Engine torque multiplication takes place at the transmission first, (obviously) then the tcase, then the axles. Generally speaking....upgrading things at the end of the stream doesn't usually affect things upstream from that component.
Sure, put in a set of 2.5T 40 spline 2" diameter Rockwells, bind your FJ up in some position where it cannot move but something has to give, and you'll likely blow a driveshaft instead of an axle.
But.....from what I'm finding with my drivetrain (22re Toyota 4 cylinder, W-56c stock Toyota trans 3.97:1 first gear, stock geared (but cryo'd) 2.28:1 first tcase reduction box, 5.0:1 Atlas II 2nd tcase, stock Toyota double cardan joint/standard Toyota ujoint drivelines, 35 spline D60s with 5.86 gears)....axles still break before anything else.
HTH,
Sean
