Go Back   Toyota FJ Cruiser Forum > Supporting Vendors > All Pro Off Road
All Pro Off Road All Pro Off Road is a supporting vendor of FJCruiserForums.com!
Old 05-13-2008, 04:52 PM   #1 (permalink)
Pittfiend's Avatar
Member Number: 17068
FJ Cruiser Rock Jock Dana 60 Rear Housing
This is the new All-Pro / Currie Rock Jock Dana 60 rear end for the FJ, the ultimate cure for the broken rear ring & pinion sets common to the FJ with the stock rear end. Better clearance under the driveshaft is attained though the high pinion design, and the beefier 9.75" ring gear (compared to the 8" OEM Toyota setup) really adds strength. You also have less to get hung up on as the entire underside of the differential section is a smooth radius that slides over rocks, with NO LOSS OF GROUND CLEARANCE! And for those wondering about the brakes; it uses the factory setup, so the ABS and A-TRAC are fully functional. As a bonus, you also get a 3 position adjustable panhard mount bracket standard to keep your axle in the correct position regardless of the amount of lift you have installed.
We have 5 in stock! Order yours now!
Pittfiend is offline
Old 05-13-2008, 04:59 PM   #2 (permalink)
Raptor-nator
Shadow-Warrior's Avatar
Member Number: 3913
Re: FJ Cruiser Rock Jock Dana 60 Rear Housing
Nice....another item to add to my ever growing MOD list.
"It’s Not An Assault Rifle, It’s a Jihadi Paradise Attainment Facilitator"
TLCA Member : #18084
Honorary AZFJ Club Member
FJ Cruiser Club Member
Meet The RAPTOR 2007 TRD SE
Shadow-Warrior is offline
Old 05-13-2008, 05:02 PM   #3 (permalink)
razr's Avatar
Member Number: 8924
I know I can't afford it ,but how much $?
razr is offline
Old 05-13-2008, 05:05 PM   #4 (permalink)
Pittfiend's Avatar
razr previously said: View Post
The housing and the axles is $2200
Get the housing, axles, your choice of gears and ARB locker for $3500
Old 05-13-2008, 05:15 PM   #5 (permalink)
5280FJ's Avatar
Member Number: 7663
So, this may be a big leap, but at what point in an FJC no longer an FJC??
Years ago, I owned a '47 CJ-2A, when I looked seriously at upgrading the engine, it pretty much meant upgrading the whole drive train, etc. It ended up looking like buying a used CJ-5, etc, and putting my freshly painted CJ-2A body on it somehow...
For specific needs this is great, but no info on once you beef up the axles, what stress you get on the drive line all the way back to the piston rings... Info on clutch plates, etc?
Are you the new guy at AllPro? Any intro for us slow people? Thanks!!!
5280FJ is offline
Old 05-13-2008, 05:26 PM   #6 (permalink)
JonB's Avatar
Member Number: 2515
5280FJ previously said: View Post
Chris is relatively new at All-Pro. He is a college student who works part time for us taking product photos and doing web related tasks.
And the way things are progressing around here we'll have those heavy duty piston rings shortly. LOL
JonB
http://www.allprooffroad.com
JonB is offline
Old 05-13-2008, 05:30 PM   #7 (permalink)
5280FJ's Avatar
Member Number: 7663
JonB previously said: View Post
JonB
Jon, thanks for the reply.
Wish Chris the best there. Terry already bleed my wallet for most of your products. (have to send pict soon) Glad to know you keep moving forward.
Hopefully a few more miles before piston rings are needed... :-)
5280FJ is offline
Old 05-13-2008, 05:41 PM   #8 (permalink)
Pittfiend's Avatar
Thanks. Terry will still take your money, but if you send me some good shots of your FJ I'll see if I can't use it on the site.
Old 05-13-2008, 05:43 PM   #9 (permalink)
2007fj's Avatar
Member Number: 4059
Are driveshaft modifications required ? Price seems reasonable given the amount of work that must has gone into this.
2007fj is offline
Old 05-13-2008, 05:52 PM   #10 (permalink)
layonnn's Avatar
Member Number: 10006
Is any welding required? Or is it bolt up using stock links and what not. If you buy it with the gears and locker, does it come put together?
Layton
2007 FJ Cruiser 5AT 4x4
Voodoo Blue
"God forgives...rocks don't"
layonnn is online now
