Go Back   Toyota FJ Cruiser Forum > Toyota FJ Cruiser Discussion > Camping Equipment
Camping Equipment This forum is for discussing camping equipment.
Old 09-25-2008, 01:52 PM   #1 (permalink)
BigBlu's Avatar
Member Number: 18013
Hitchmount Food Prep Table
I was looking at camping gear getting ready for a few trips this fall and winter and I saw a blender mount for the rear hitch. The mount included a cutting board "to cut limes for your margaritas". This got me thinking...
1) Does anyone make a table/food prep table that uses the hitch as a base?
2) could I make one of these...the only problem here is I can't weld and I don't think that wood would hold up too well to the elements.
Any thoughts? I drew up some plans but I don't have access to a scanner right now so I can't post them. Mine is a simple design - and L shape on the bottom that slides into the hitch receiver and a T shape on the other end with three hinges that hold the table. You lift the table and a bar comes down and secures into the down tube of the T. Hopefully this gives you some sort of visual....
BigBlu is offline
Old 09-25-2008, 02:08 PM   #2 (permalink)
Constantine's Avatar
Member Number: 12716
Re: Hitchmount Food Prep Table
Hitch tables
Tailgate Table - Dine in Style with the Tailgate Table
TableGater, the Adjustable Height Trailer Hitch Tailgating Table
The Hitch Corner sells receiver hitch tailgating table
Game Day Hitch Mounted Tailgate Table
Boone Outdoor Hardware Tailgate and Storage Gear
Constantine is offline
Old 09-25-2008, 02:19 PM   #3 (permalink)
Super Moderator
Fjamming's Avatar
Member Number: 6623
What about something like this?
My setup will hold 20lbs easily. No rattles and it's not very heavy.
Sandoo Blue FJ
SoCal Events Calendar
Fjamming is offline
Old 09-25-2008, 02:23 PM   #4 (permalink)
BigBlu's Avatar
Thanks! I probably should have googled it before posting this. I don't know that these will work with the spare tire...at least not in the taller position which is more along the lines of what I'm looking for.
BigBlu is offline
Old 09-25-2008, 02:30 PM   #5 (permalink)
BigBlu's Avatar
I like that a lot and thought about it when I first saw it but I built a storage box inside and I wouldn't be able to close the door. Have you done any cooking on it?
BigBlu is offline
Old 09-25-2008, 02:32 PM   #6 (permalink)
pokerDawg's Avatar
Member Number: 12463
I'm so pissed at myself. I added a cargo net storage to my door. I was wondering if I should install it high or low. I freaking installed it low!! Now I can't do Tony's table mod
My FJ Cruiser videos on YouTube and Vimeo
pokerDawg is offline
Old 09-25-2008, 02:35 PM   #7 (permalink)
abophx's Avatar
Member Number: 3960
Man that is the coolest mod I've seen.
Very practical.
Back to the original question, I would think a hitch mounted table to be in the way.
I've found the the Coleman 30" by 60" folding table fits perfectly behind the seat.
YOUR PERSONAL FUKIN RAY OF SUNSHINE
Blue MT6
abophx is offline
Old 09-25-2008, 02:37 PM   #8 (permalink)
Super Moderator
Fjamming's Avatar
Member Number: 6623
I have not cooked on it. I was afraid the heat might affect the backing on the door. I've picnic off it many times. How much room do you have between the box and the door? The tray sits in the groov when folded so it doesn't stick much at all. I can measure it tonight if you want me to.
Here's another view.
Sandoo Blue FJ
Fjamming is offline
Old 09-25-2008, 02:44 PM   #9 (permalink)
BigBlu's Avatar
When the door is closed the box touches the spot between the two indents in the door.......where's that "if I did it all over again, I would...." thread.....
BigBlu is offline
Old 09-25-2008, 02:47 PM   #10 (permalink)
Super Moderator
Fjamming's Avatar
Member Number: 6623
BigBlu previously said: View Post
You've built a big box . Good luck with your search.
Thanks for the kinds words PokerDawg and Abophx!
Sandoo Blue FJ
Fjamming is offline
