Go Back   Toyota FJ Cruiser Forum > Supporting Vendors > Demello Offroad
Demello Offroad Demello Offroad
Old 04-01-2008, 10:56 AM   #1 (permalink)
Member Number: 17057
Touch up on Plate Bumper
Jason,
I just got my new bumper and it's awesome. There are a few scratches from shipping and I wanted to know what paint I should use for the best color match. Thanks.
charliem is offline
Old 04-01-2008, 11:33 AM   #2 (permalink)
Member Number: 639
Re: Touch up on Plate Bumper
What finish came on your bumper? You can always pickup a can of spray paint at the local hardware store and spray a test spot on the back side of the bumper. It will never been seen once installed. I use duplicolor semigloss black on mine.
sbechtold is offline
Old 04-01-2008, 11:52 AM   #3 (permalink)
codymurfy's Avatar
Member Number: 17351
Arent jasons bumpers powder coated? How would spraypaint hold up
Its an FJ thing!
TLCA:18474
Check Out my build in progress:http://www.fjcruiserforums.com/forum...tml#post848167
codymurfy is offline
Old 04-01-2008, 12:21 PM   #4 (permalink)
Member Number: 3240
charliem previously said: View Post
Jason,
Home depot carries a wrinkle finish spray paint. I think its called texture paint. You can try that.
JDEMELLO is offline
Old 04-01-2008, 12:30 PM   #5 (permalink)
Mtbcoach's Avatar
Member Number: 2433
JDEMELLO previously said: View Post
I've used that and also found the Duplicolor "Truck bed paint" is a good match also. The advantage of the Duplicolor is you can get it in a brush on can and applying it with a cheap sponge roller gives a very close match in color and texture...
'07 GSJ15, well enhanced
'97 FZJ80 OME J
'77 FJ45
Olde North State Cruisers TLCA delegate
Train Hard, Rest Harder
TLCA 17784 - FCC KJ4KGF
Mtbcoach is offline
Old 04-03-2008, 06:03 PM   #6 (permalink)
Thanks guys. I have the Rustoleum Textured paint so I will try that first.
charliem is offline
Old 01-23-2009, 11:36 AM   #7 (permalink)
Cogen Man's Avatar
Member Number: 3269
Mtbcoach previously said: View Post
I have a spot above the passenger side light bucket that the powdercoat came off. Was some ugly rust underneath. I'm going to use the Duplicolor Truck bed paint with the roller to redo my DO bumper. The roller kit comes with a scotch brite pad to ruff up the surface and remove the rust. If that doesn't hold up, it's Line-X time. Just had my rock rails done and they look great.
Silly Wabbit
Mods:
BFG AT's, stone guard,vent visors,window tint,blacked out bezel/rear bumper.
Joels grab handles. See Avatar.
Demello front winch bumper/center hoop/Acro lights
Titan 12k winch,recovery gear
Scangauge II
Joel's FJC badge
Gobi Ladder
Custom rock rails
Quick Fist Clamps
Tuffy security console
Future Mods:
Demello rear bumper
http://www.fjcruisersontario.com/wordpress/
Cogen Man is offline
Old 01-23-2009, 11:44 AM   #8 (permalink)
Member Number: 19778
Thanks gang. I have this problem with my new powder coated bumper: A scratch where it must have been riding on something and then a scrape next to it. I like the idea of brushing the paint on. Do you recon a primer would be a good idea for the paints?
HMRRSQ is offline
Old 01-23-2009, 12:28 PM   #9 (permalink)
Cogen Man's Avatar
Member Number: 3269
HMRRSQ previously said: View Post
I'm thinking a primer would be a good idea. If you have to sand off any rust down to bare metal then I'd recommend a primer before the paint. If the coating you have on the bumper is rough or textured then the primer probably isn't needed. If it's a smooth surface then I'd rough it up then re-paint without the primer.
Silly Wabbit
Mods:
Scangauge II
Joel's FJC badge
Gobi Ladder
Custom rock rails
Quick Fist Clamps
Future Mods:
Demello rear bumper
Old 01-23-2009, 01:19 PM   #10 (permalink)
Cogen Man previously said: View Post
I'll try it! Thanks
HMRRSQ is offline
