layonnn previously said:
Are you dead set on it being on the side of the rack? I have mine on the back on the lower tube and it isn't even close to hitting. I am considering moving the mounts to the top tube in the rear to allow back up lights on the roof rack.
Doesnt matter what tube it is on, it is still the same size tube and the mounts dont change "depth" at all so the ratcheting mech. still hits the rack before i can put the wing nut on.
potatomutato previously said:
have you tried angling the mounts so that they point upwards slightly?
Yes i have tried to angle it, doesnt make a difference, unless i were to angle it so far that the ratcheting mech. would acutally hang off to the side of the truck and the jack would be almost inside the top part of the rack.
JDEMELLO previously said:
I can't tell from the pictures but the jack looks upside down? It should have the handle on top.
Very first sentence in my first post explains why it is on "upside down"...with the handle on top i cant even get the studs to poke through the hi-lift becasue the ratcheting mech. hits the rack.
AmityFJ previously said:
You might want to rethink where your hi-lift is. The back is a better position if you need it on the rack. On the side it can get caught up on tree branches and other things on the trail side.
Isnt yours mounted on the sides in the pics in your signature?
Did you move it to the back? I'm honestly not to worried about it getting drug through branches, 99% of the trails this thing sees there is little to no chance of it dragging trees.
Thanks for all the suggestions, still dont know whats up with it.
