Diode Dynamics: LEDs vs. OEM incandescents - Toyota FJ Cruiser Forum
 1Likes
  • 1 Post By Voight Kampff
post #1 of 3 (permalink) Old 09-03-2014, 12:00 AM Thread Starter
Voight Kampff's Avatar
Quoted: 1228 Post(s)
I ordered some LEDs from Diode Dynamics last week.
I went for cool white colors, in the lowest-power configuration. I'm not looking for blazing power with license plate lights, backup lights, or interior lights.
I started off by swapping out one of the two license plate lights.
Bulb on the left is the OEM incandescent.
Bulb on the right is the Diode Dynamics cool white, SMD1 (16 lumens).
It's not much brighter, but that's not the point. I'm looking for more efficient, and less draw on the system. These run very cool.
I installed the rear dome light in cool white; the SMD6 Board (56 lumens). Hard to take pictures of this with an iPhone camera, but this should show something of the sort. Light is much cooler temp than stock, and, even though I went with the lowest-output light, it was much brighter than stock. Light went in with a bulb replacement with a pair of power wires out to a flat circuit board with 6 LEDs in it; sticks to the inside of the light with a piece of double-sided tape.
DD LED in foreground; OEM behind.
Build quality and packaging are really nice. Designed and tested in the USA, assembled in China.
I'm going forward with more purchases from DD to replace the rest of the interior lights, turn signals, and side markers. My expectation is that the electrical draw will come down a little bit with these, but every bit counts.
Diode Dynamics likes this.
What size tires will fit on my FJ?
The owner's manual for your FJ is right here. <--- This is a link. Many answers to your questions are contained within.
See the relationship between highway speed and MPG here.
TLCA 5301
Voight Kampff is offline
post #2 of 3 (permalink) Old 09-03-2014, 12:38 AM
bazross's Avatar
Quoted: 1362 Post(s)
Re: Diode Dynamics: LEDs vs. OEM incandescents
G'day,
Looks good, I have replaced all my oem bulbs with LEDs, for the same reason, eco-friendly...
When you do the indicators, don't forget to swap out the controller for a LED flasher unit.
Its a PITA to get to, up under the dash, behind the fuse box, but once done ..its done... and the indicators will flash correctly....
Cheers
Baz
bazross is offline
post #3 of 3 (permalink) Old 10-07-2014, 03:26 PM
Diode Dynamics's Avatar
Quoted: 41 Post(s)
Thanks for the review!
Have you submitted any photos yet? We have introduced several new bulb models recently, and the SMD1 is very much an entry level LED bulb option
Nick C.
Diode Dynamics is offline
  Toyota FJ Cruiser Forum > Supporting Vendors > Diode Dynamics
Human Verification
