Go Back   Toyota FJ Cruiser Forum > Supporting Vendors > Ellis Precision
Ellis Precision Ellis Precision
Old 08-21-2007, 03:57 PM   #21 (permalink)
Member Number: 12687
Re: Yakima-Style Towers?
FJoel previously said: View Post
The regular ones for hi-lifts are... I kind of slowed progress on the modified ones now that San Frantastico has the yakima adapter solution.
Oh no! I'm holding off on buying a rack for my new FJ....waiting for your modded Dom mounts...I like Fantastico's design but I'm concerned about the Yakima landing pad--isn't it all plastic?
--Darin
darinb is offline
Old 08-21-2007, 04:04 PM   #22 (permalink)
FJoel's Avatar
Member Number: 4197
darinb previously said: View Post
--Darin
They are plastic I believe. Okay, I'll try to get the loose ends all tied up and release them...
Glad there is still interest. Thanks
FJoel is offline
Old 08-22-2007, 04:02 PM   #23 (permalink)
Member Number: 2287
I'm still in line!
Sun Fusion Auto 4WD - FE, CQ, UR, Z1
Mods: BFG 285 70/17's on stock alloys, Aeroflow headlight covers, FJ3-FRCC Toytec Lift Kit with OME-N71, Demello sliders, dual rear cargo nets, stock tow hitch, DICE iPod kit, Yakima rack with StornCo adapters, SwissArmySUV Overhead map light, 2008 Side Visors
oldskoolboarder is offline
Old 08-23-2007, 10:05 AM   #24 (permalink)
SanFrantastico's Avatar
Member Number: 12658
Yeah - the Yakima Landing Pads are 100% plastic. The official rating on a 2 crossbar system is 160 pounds.
Storn
StornCo << Yakima Rack Systems for the FJ Cruiser
SanFrantastico is offline
Old 08-24-2007, 03:28 AM   #25 (permalink)
FJHokie's Avatar
Member Number: 4093
I'm still real interested in these. Need to be ready for ski season!
MT6 Titanium Base, Light Racing Coil Over Front, Light racing Shocks and Springs Rear, Fab Fours Front Bumper, Expedition One Sliders, All Phase Front and Diff Skids, All Pro Ultimate Links, 285/70/17 BFG ATs, ClearPlex, Warn XD9000i w/Superline XD Synthetic Line, A-TRAC & Mod, XM Commander MT
FJHokie is offline
Old 09-13-2007, 11:35 PM   #26 (permalink)
F@kken FJ's Avatar
Member Number: 13400
fall is here already.....and i told the dealer "no-no" to stock rack!!! how close are the mounts to production?!?
F@kken FJ is offline
Old 09-14-2007, 02:51 AM   #27 (permalink)
FJoel's Avatar
Member Number: 4197
I told them the same no-no.
I'll start a thread with the revised design, get some feedback, and we'll do the group buy.
FJoel is offline
Old 09-14-2007, 01:27 PM   #28 (permalink)
Member Number: 2287
I'm ready for the group buy!!
Old 09-14-2007, 05:40 PM   #29 (permalink)
Member Number: 12129
Send a message via AIM to 83841
Count me in.......Can we start a group buy list?
83841 is offline
Old 09-14-2007, 07:56 PM   #30 (permalink)
FJoel's Avatar
Member Number: 4197
oldskoolboarder previously said: View Post
83841 previously said: View Post
I'm glad you guys have so much faith in me, but you haven't even seen renders yet!
I've made it, if all goes well and the fit is precise, removable. I don't want to run a rack in the city, I like the smooth white top. But when I go wheeling I'd love to throw gear up there! So we are looking at a few pieces, all universal. I'll explain better in a moment.
1. Main mount: This will be a flat Dom mount with a threaded hole (stainless insert so as not to wear out) and radiused slot in it. You will use a stainless M12 (beefy and rust free) bolt to attach the second mounting part to the roof here, along with a set screw that will lock up the mount even more from rotating. All assembled it couldn't rotate anyway, but I like overdone. The beauty of this is that when you remove the rack, you will have almost invisible flush covers, that will be bolted on by stainless cap screws. Much better solution for no rack than Toyota's little clippy things.
2. Pivot mount: Will allow the 3rd piece (explained below) to pivot, as each and every set is a slightly different angle. This makes all the parts universal, and keeps your cost down. Also, better for replacing and ordering. This piece will twist along the radiused slot for alignment across the roof, and allow the 3rd part to angle itself so that both left and right mounts meet the bar at a perfect 90 degree angle.
3. Bar mount: This is the part that will house the bar. This is what I am finalizing now, as I had a better idea for a lock and release system that will aid in the "removability." This will be much more streamlined than the the original clunkers I had as prototypes.
4. Cross bar: Initially only left to right bars will be released, with longitudinal bars coming out after. I will design and make a full set of accessory mounts as well.
Now the finishing... the bars will be powder coated, as I am not about to machine 4 ft long bars :jawrop: and the extruded finish is not really suitable for a cosmetic anodize.
We could anodize everything for wear tear and corrosion resistance, then powder coat everything for a cosmetic finish. Or we could just powder coat everything. Thoughts and comments please!
FJoel is offline
