Go Back   Toyota FJ Cruiser Forum > Supporting Vendors > Ellis Precision
Ellis Precision Ellis Precision is a supporting vendor of FJCruiserForums.com!
Old 03-21-2008, 04:43 PM   #1 (permalink)
KiltedBishop's Avatar
Member Number: 5216
Attaching grill badge?
Ok am I a tard or missing hardware? I got two screws and two washers but the washers easily fit through the gaps in the grill, and don't reach all the way through, well almost. How do you attached these things? Help!
Black Cherry "Molly"
AT, Conv. Pkg, Option pkg 2, Trail Gear sliders, ARB Bumper, All Pro Coil Overs w/resivoir, Hood Protector, Window Ventshades, PIAA 520 Driving Lights, Python Remote Start, Wet Okole seat covers
It's good to be God
KiltedBishop is offline
Old 03-21-2008, 05:01 PM   #2 (permalink)
Raptor-nator
Shadow-Warrior's Avatar
Member Number: 3913
Re: Attaching grill badge?
I found it best to remove your front grill, then I used some fender washers that were bigger, then tighten it down...Mine is on there real good, it's not going anywhere...I hope this helps.
"It’s Not An Assault Rifle, It’s a Jihadi Paradise Attainment Facilitator"
TLCA Member : #18084
Honorary AZFJ Club Member
FJ Cruiser Club Member
Meet The RAPTOR 2007 TRD SE
Shadow-Warrior is offline
Old 03-21-2008, 05:11 PM   #3 (permalink)
Member Number: 5216
Yep thanks. I was wondering if that was all it was. I thought maybe there was a trick to it.
It's good to be God
Old 03-22-2008, 11:30 PM   #4 (permalink)
FJoel's Avatar
Member Number: 4197
KiltedBishop previously said: View Post
I pitched those holes out to 25mm on my grille so those wahsers would work, but if the screws aren't fitting I must have sent you the wrong length...? I only stock 5mm for grille badges thus far so maybe I ordered a box of wrong hardware. I will check and send you the correct hardware if need be.
Sorry Bishop!
WANT MORE FROM YOUR FJ? Click one of the links below!
Brought to you by Ellis Precision:
Group Buy: JBA Cat-back Exhausts and Headers
Group Buy: aFe Cold Air Intakes and Throttle Body Spacers
Group Buy: aFe Cat-back Exhausts!
FJoel is offline
Old 03-23-2008, 08:26 PM   #5 (permalink)
Member Number: 5216
FJoel previously said: View Post
Sorry Bishop!
You did this on purpose didn't you? hahahaha Just making me wait a little longer.
It's good to be God
Old 03-24-2008, 02:50 PM   #6 (permalink)
FJoel's Avatar
Member Number: 4197
No way!
So did you need new hardware? The difference in length was only a couple mm and probably wouldn't have mattered.
These things are giving me NIGHTMARES!
FJoel is offline
Old 03-24-2008, 04:12 PM   #7 (permalink)
Member Number: 5216
No way!
I'll take the grill off and try it and let you know. Bet you didn't think it was going to be that big a pain when you agreed to it huh?
It's good to be God
