(Okay this isn't really engine tech, but this seemed like the best place to post this. Mods: move this if needed)
Yesterday I went on this 6-hour run which was quite dusty to say the least. I had left my ventilation set to Recirculate so the dust wouldn't get in. Towards the end of the run, I noticed the Recirculate switch would change modes on its own, letting "fresh" dusty air in. I lost count of how many times I had to turn Recirculate back on, but this was happening to all the other FJs on the run. Our guess was that it was resetting because the in-cabin filter was clogged. So on the way back home, I decided to stop by the dealer and pick up a new filter.
This morning, I opened up the glove box to get to it (it's in your manual -- page 178), and found a very dirty filter. Here's a comparison shot:
I had around 4000 miles before the trail run so it couldn't have been too dirty before then. And this photo was taken after I shook some dust off the old filter while taking it out of the holder, so it was much dirtier than pictured. You could hit it with a wet noodle and a pound of dust would rain down from it.
When the recirc button reset on its own, I saw a bit of dust coming through the vents, so I knew there had to be some dust in the system between the air filter and the vents. I wanted to try to flush all that out so what I did was take some compressed air and blow it all around inside the blower assembly:
Also stick your finger in there and rotate the fan blades around so that they all get evenly covered with a blast of compressed air:
Dont make the same mistake I did -- unless you want to get dust sprayed all over your interior, get some damp towels and cover up the vents. Also cover up the side vents too.
I didn't figure this out until I first started blasting away, so I still have some wiping up to do on the interior.
So there you have it -- my needlessly lengthy post for a terribly easy procedure.
That thing is worthless! Mine is always clogged I have cleaned it about 4 times in 7000 miles. Over at TTORA there was a suggestion to replace it with a 3M home filter and just cut it to size. I am not sure what the dealer wants for a new one, but I place it in the same group as the plastic cover on the skid plate. Good idea to blow all the dirt out of the vents.
Rep points comming your way dude. I would have NEVER thought of the damp towel thing over the vent's. After yesterday, I needed to do some clean up too! OBTW: The recirc. problem everyone was having was because of low outside temps, not our filters needing service.(although they DID NEED to be looked at.) What the heck was Toyota thinking:" Replace cabin filter at 60,000 miles"!
SF, A/T, Conv Pac,Aeroflow HLC's, Demello sliders, Demello Skid plate, OME 2" lift, BFG A/T, K&N filter, Magnaflow exhaust, KC 100 watt and 130 watt slim lights, Two tone air horn,Demello prerunner bumper, rear tow hitch,Allpro LCA's and Skids, Mile marker PE8000 winch, Amsteel blue winch rope, Delrin fairlead rollers, Demello 2wd tranny skid.
Treadlightly member.
Thanks
Yeah I'm thinking I might do that the next time this needs replacement. When I took it out, I was expecting a HEPA type filter with a ton of pleats but this was A LOT flimsier and porous than I thought. I got it for less than $20, but still, it's a really thin filter that probably cost Toyota 5 cents to make.
After reading this, it prompted me to check all my filters last night. What I found:
1. the air filter is really dense and for the most part clean
2. the inner air filter is clean, but I have no clue as to what it is for
3. the cabin filter had about 6 small leaves in it. Now how in the hell do I get leaves in the INNER cabin filter. Im talking twice as many as in my engine air filter?
Zane
2007 Titanium 4x4 AT
Convenience Package, Upgrade #2
275/70 MT/R's, ARB, Warn M8000, 2.5' front leveling spacers, IPF 968's, original cut-hack, TRD sliders, Cobra 75WXST w/ Firestick, dbbd1's hi lift brackets & hi lift, K&N drop in
