Got the rig back from Burt Toyota today.
Took them 2 days and part of the morning to get the supercharger installed, oil/filter change, rotate/balance the tires and an alignment. Total damage for all of that.........$1114.00
Here ya go:
TRD suggested re-installing the OEM intake, but the tech said to leave the AFE on for better performance and said it would not effect the warranty. They did have to improvise a mounting bracket for the coolant pump since the ARB and winch interfered with the TRD provided bracket behind the grill.
Work in progress:
This pump needs to go in front of the radiator, but the ARB and winch drum interfere.
So an improvised bracket wil relocate it behind the ARB and the winch motor. Will require some different coolant fittings and pigtail on the wiring harness.
Sorry for the poor quality pics, but I was on the run and the techs stayed late to problem solve and show me the quandary.
Installed with the afe CAI no problem
New coolant reservoir
The supercharger
Coolant hoses run along the back of the drivers side engine compartment
And along the inside of the driver's fender behind the fuse blocks and battery
A very tight fit for the relay and wiring harness along with the coolant lines
They also run behind/through the drivers light housing access
New hood latch bracket and low-temp radiator
We had to relocate the pump toward the passenger side b/c of the ARB/winch
Pump is mounted on the frame instead of the provided bracket
The new pulleys and belt will make changing the drive belt fun
Because it's behind all of them
Haven't had the opportunity to really play with it yet, but plan on hitting Floyd Hill west of Denver this afternoon!
