Old 11-20-2007, 10:19 AM   #11 (permalink)
TCao's Avatar
Member Number: 940
Re: A/C Filter Change
Here's Ollie's post over there: foam cabin air filter. It's an industrial-grade dual density foam designed for use in paint booth and grind booth pre-filtration.
That's the main reason I went back to the factory filter. TRDSource has the lowest price I've found (~$14).
2007 Ti FJC
TCao is offline
Old 11-20-2007, 10:44 AM   #12 (permalink)
jeshua's Avatar
Member Number: 6888
Thanks for looking Ollie's thread up T.
That's a quarter the price my dealer charges! I need to make a bulk order from him of these and Toyota Oil filters.
Mike Ambs
www.corva.org
- Thomas Paine
Aequitas - Veritas
jeshua is offline
Old 11-20-2007, 07:08 PM   #13 (permalink)
sonof40's Avatar
Member Number: 11473
uphill previously said: View Post
Everybody (yes including me) is in a hurry to mod what the factory engineers have come up with. However, there is also the philosophy of understanding why a wall was erected before you rip it down...
I don't usually like to waste bandwidth with "ME TOO" but X2 on this one.
Steve
TLCA
Sleeping/Storage build: http://tinyurl.com/367bbw
CB: Cobra 75 / Bandi http://picasaweb.google.com/steven4m/CBInstall
Back Door Inside Latch: http://tinyurl.com/2jxwkk
sonof40 is offline
Old 11-20-2007, 08:09 PM   #14 (permalink)
iCruiser's Avatar
Member Number: 479
Here's some photos of my mod...
Get Filtrete Filter,
Kinda tricky to cut since there is a thin metal grate on the front and back.
Cut to size. I don't have a problem with leakage on the sides..
So far it works great, and I've had it in for about 2 months!
T
iCruiser is online now
Old 11-20-2007, 08:25 PM   #15 (permalink)
w5wi's Avatar
Member Number: 11734
Larry,
Thanks for the info! I tried to give you some rep points, but couldn't...
We all appreciate your efforts!
cheers,
dale
Happy Trails!
TLCA #17625
LOS TRES AMIGOS IN MEXICO
TITANIUM METALLIC--A/T
ARB Bumper - Warn Winch - OME Heavy 886/895 - Bandi Mount - All-Pro Lower link skids - Bud Built skids - Snorkle - Toyota prefilter (cyclone air filter) - Optima Yellow Top Battery - Painless Dual Battery Control System - Scuba Driver Mod - Kenwood DNX 7120 GPS - A-TRAC mod - 110v add-on - Rock Rails - Rear Locker - Roof Rack - BFG TA/KO's - ARB Fridge/Freezer - '08 side visor mod - Royal Purple fluids - E3.68 Spark Plugs - All Pro Rear Bumper - All Pro Lower Links - M-Pac rear and side mounts
To be continued...
w5wi is offline
Old 11-20-2007, 08:29 PM   #16 (permalink)
Member Number: 1103
In the owners manual, it also says that you can used compressed air to blow out the dirt. This would extend the life of the filter and save you a few dollars.
SEMPER FI is offline
