Is the horse power i got with supercharger enough? - Page 2 - Toyota FJ Cruiser Forum
» Auto Insurance
» Featured Product
Register Home Forum Active Topics Photo Gallery Chat Insurance Garage Blogs Search Today's Posts Mark Forums Read
Old 02-12-2012, 09:29 PM   #11 (permalink)
NestahEdition's Avatar
Member Number: 10370
Re: Is the horse power i got with supercharger enough?
With my Unichip only (no S/C), my last dyno run was 216.8 WHp, 252.6 Ft-Lbs. torque.
TLCA #17592
2007 FJ Cruiser 4x4 Auto Titanium Silver
Mods too long to list
http://norcalfjs.ning.com/
"The silent force"
NestahEdition is offline
Old 02-12-2012, 09:39 PM   #12 (permalink)
bulldog6's Avatar
Member Number: 48847
What are your manifold pressures hitting?
'11 Cavalry Blue
Off-road package, convenience package, hitch.
Done: RA3200 Security, remote start, Wade vent visors, camping/fishing gear, Tuffy Security Console, Tuffy Concealed Storage, tail light guards, HAM radio.
To Do: Hood and pillar vinyl, Freedom Windows, aux lights, BW pocket flares, rear door storage, wheel paint, A/T tires, long travel...
bulldog6 is offline
Old 02-12-2012, 10:15 PM   #13 (permalink)
Member Number: 40091
NestahEdition previously said: View Post
i got 197WHP with 33" tire size..
i think i'm less hp because of the elevation here in Colorado. so i guess you're in California, if you supercharge you'll get 300+
Talal is offline
Old 02-12-2012, 10:16 PM   #14 (permalink)
bulldog6 previously said: View Post
i didn't understand that
Talal is offline
Old 02-12-2012, 10:36 PM   #15 (permalink)
bulldog6's Avatar
Boost=manifold pressure. The Trd kit should be around 5-6 psi. The smaller pulley should get you a little more, but how much? Also, were your expectations based on engine hp, or wheel hp? Wheel hp is always going to be lower. A 70hp Increase at the wheels is pretty respectable. What are your torque numbers? If you want high output, the trd kit is not the best route. It is arguably the most reliable solution though.
'11 Cavalry Blue
bulldog6 is offline
Old 02-13-2012, 01:22 AM   #16 (permalink)
boost is almost 6 as the tuner said "with the smaller pulley" also , he said if you use the TRD pulley you'll have less boost because of the altitude here in Colorado .
the torque is 285.3
and yeh, that's why i got the TRD coze it's reliable, even thought that i spent so much time thinking about the URD kit.
I would appreciate all your responds here and thank you for participating in this thread.
I will be taking off the 3" lifting kit in summer and will get the stock tires, will retune it at that time and find out how it will be.
Talal is offline
Old 02-13-2012, 03:14 AM   #17 (permalink)
Ohnoitsthecops's Avatar
Member Number: 47671
thats great actually. you need to look at it like this your using an exhaust thats built for N/A an intake thats built for N/A. theirs more power to be had you just need to get your system built around your forced induction now.
Ohnoitsthecops is offline
Old 02-13-2012, 03:25 AM   #18 (permalink)
PSYCHO BILLY's Avatar
Member Number: 49294
Talal previously said: View Post
the tuner tuned the unichip from the beginning because the map it has suposed to go with DT and air intake and filter. as he said "timing is good and i don't want to change it, A/F is about in mid 11"
I also got the Flux2 "new product from unichip" which allows to have 5 different map. I asked him if he can use 2 maps one for fuel efficiency and another for racing, just to have more hp" but he said you'll need only one map. when driving normal it will be fuel efficiency and when pushing the throttle it will be fast and consume more gas.
the thing is.. TRD supercharger should increase the horse power by 80-110 hp.. and i only got 73 even though i have the smaller pulley
I think you want to be at 14.7:1 A/F... 11:1 seems awful rich..
Lugnut & Psycho Billy
Members of the 20%
"Everything should be as simple as possible, but not simpler."
Albert Einstein
"What are we, compared to the greatness of destiny?"
Unidentified Soldier, Germany, 1939
"20% of the people are awake and guarding the constitution and your individual rights, 80% are happy to continue grazing. What group will your children remember YOU belonging to?"
Yellow Wasp
"If You are not part of the solution, You are the problem."
WMC
PSYCHO BILLY is offline
Old 02-13-2012, 03:38 AM   #19 (permalink)
PSYCHO BILLY previously said: View Post
14.7 IS what you want at idle and cruising to save gas, under load you want around 12.5 n/a and under boost i was running as much at 10.5 on my civic and evo. trust me you want the tune to be on the rich side to avoid detonation, the small amount of power youll get will be offset if your motor ****s the bed.
Old 02-13-2012, 03:52 AM   #20 (permalink)
FJNewb's Avatar
Member Number: 19411
Brian, by "adaptive", do you mean that it (or some solutions?) will calibrate/compensate to an extent by itself? Do some units actually "tune" themselves and adjust to A/F ratio?
Within certain envelopes the x1 and ucon can self tune for modifications. It won't be the most agressive adjustment, but its better than most ems. Both actually attempt to protect your engine to a degree (less likely to go boom) if you are going outside safe operational limits. Unichip doesn't offer those same features.
OP give URD a call and ask to talk with Gadget, he should be able to give you some feedback and guidance.
FJNewb is offline
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
