Strange Engine Idling - Toyota FJ Cruiser Forum
» Auto Insurance
» Featured Product
Old 11-20-2012, 01:08 PM   #1 (permalink)
Member Number: 62141
Hey Guys,
I just bought an 07 FJ, absolutely love her so far, but I've noticed that it's constantly changing idle speeds every 10 seconds cycle between 1k RPM and about 900 RPM. It's not idling rough, it'll just go 900 for 10 seconds, then 1000, then 900 etc... I noticed that the cooling fan is also constantly running, even at cold start, so it's not that turning on/off. Any idea's on what it could be? Almost seems like a relay or something kicking in putting extra load on the alternator?
Thanks!
iceman153 is offline
Old 11-20-2012, 01:22 PM   #2 (permalink)
Smalldog's Avatar
Member Number: 54049
Thermostat? Does your temp gauge look good?
Sent from my iPhone using AutoGuide.com App
2007 Voodoo 6MT
All Pro Walker Evans lift w/AP rear coils and ext brake lines
All Pro Uniball UCAs
Skyjacker extended rear swaybar links
BMC
LCNW Front Tube Bumper
All Pro Heavy Duty Sliders
Ricochet HD Skids
285 70 17 Duratracs
Spidertrax 1.25s
Steelies
PiAA Ion Fogs
URD Quickshifter
ARB Awning
Blue Sea Fuse Blick
AFE Pro-S Dry Air Filter
Wet Okole Seat Covers
TRD Shift Knob
IMP T Case knob
Crawlorado Hood Decal
Smalldog is offline
Old 11-20-2012, 01:23 PM   #3 (permalink)
cnckart's Avatar
Member Number: 24296
Re: Strange Engine Idling
If you have it on defrost it also runs the AC compressor, that could cause an idle fluctuation.
MY BUILD THREAD
THE SPACE CRUISER
Thanks to the following people and companies that have contributed to my build:
Arien and Jason @ Demello Offroad
Doc @ Springtail Solutions
Krista and Peter @ Moto Alliance
TLCA# 20167
http://www.ricochetoffroad.com/
Get_Lost previously said: View Post
I'll believe that corporations are people when Texas executes one of them.
cnckart is offline
Old 11-20-2012, 02:00 PM   #4 (permalink)
Wow, fast replies, you guys rock So I just went down and listened for a while, I didn't quite get the symptoms right, and it's probably not an issue (only had her 2 days now!). So on first cold start, it'll idle at 1100, then slowly go down to about 750, then almost immediately I hear a relay click in the engine bay, and it jumps up to 1,000 and slowly comes back down to 750. It keeps doing that cycle (click, 1000 -> 750) for a while and eventually settles down and stops, warm idle is 700. The temp guage shows just a touch below halfway between hot and cold, which seems normal. But as once she fully warms up it calms down i'm guessing this is just the normal warm up procedure and I got ahead of myself thinking it was an issue Just felt strange hearing it bounce up and down like that
The engine idles pretty smooth, but it's quite loud, definitely has way more lifter type clicking/tapping noise going on than i'm used to, not sure if that's normal for these engines or not. Nothing I can hear from inside the car, but it's very noticeable just standing next to the truck with the hood closed. I did check the emissions unit that people have said makes a click and it's not that (I disconnected it). Does this seem normal to you guys? I might take off the engine cover and poke around with a stethoscope later when I get time.
Thanks!
Old 11-20-2012, 02:27 PM   #5 (permalink)
Smalldog's Avatar
Both brad and I have MTs, and I assume you have an AT? Maybe that is normal with the AT. We need an ATer to chime in. I don't think it should fluctuate back and forth on the rpms. Starting higher and dropping is normal but not getting high again, etc and on and on..
2007 Voodoo 6MT
BMC
Ricochet HD Skids
285 70 17 Duratracs
Spidertrax 1.25s
Steelies
PiAA Ion Fogs
URD Quickshifter
ARB Awning
Blue Sea Fuse Blick
TRD Shift Knob
IMP T Case knob
Smalldog is offline
Old 11-20-2012, 03:22 PM   #6 (permalink)
Actually no, I have a MT... It is a little strange, but does seem to stop when she's fully warmed up. I guess I'll have to drive her some more and see if it happens at any other times. Any comments on the engine noises?
Old 11-20-2012, 03:27 PM   #7 (permalink)
Winterpeg's Avatar
Member Number: 18294
x2 on the question whether it's on Defrost, defrost/feet mix, or a/c.
All of the above will cycle the a/c system and cause power fluctuations as it kicks in. This can also cause the notorious "bump" feeling at a stop light if you don't have your foot on the brakes hard enough.
Give her some love too... change the plugs, filters, oil, clean MAF and throttle body.
Suck it up... it's only -40
2008 FJ Trail Teams
ARB Front Bumper; Apex rocksliders; 2x IPF lights on bumper; ARB Full Roof Rack W/ Grid; ; Old Man Emu suspension; magnaflow muffler (mashed the original); Warn M9000 winch; 48" hi-lift extreme jack; 285/75/16 Duratracs; Ricochet skids, full set HD, black anodized; Uniden PC78 Elite CB (ch 8 typically, ch 19 on the hwy)
Excellent parts source:TRDParts4U
Winterpeg is offline
Old 11-20-2012, 04:09 PM   #8 (permalink)
Sorry, i missed the defrost q, I don't think it was on defrost, or had the AC on, but I'm not sure, and it did sound an awful lot like AC compressor turning on. I'll check it next time, good call.
Definitely going to be giving her some lovin this weekend, i'll probably do all of your suggestions, as well as tracking down the source of the ticking.
Old 11-20-2012, 05:14 PM   #9 (permalink)
Member Number: 60468
Beside the ac compressor clutch it could also be the cooling fan.
Tofu is offline
Old 11-20-2012, 05:29 PM   #10 (permalink)
Smalldog's Avatar
When warmed up, my MT idles at 700 RPM in neutral. If I turn on the AC it idles at 800 RPM. It never fluctuates in either of the modes above. I think it's the fact that your fan is always on..or whatever is causing it to be on.
2007 Voodoo 6MT
BMC
Ricochet HD Skids
285 70 17 Duratracs
Spidertrax 1.25s
Steelies
PiAA Ion Fogs
URD Quickshifter
ARB Awning
Blue Sea Fuse Blick
TRD Shift Knob
IMP T Case knob
Smalldog is offline
