Old 11-30-2006, 04:48 PM   #1 (permalink)
JLam's Avatar
Member Number: 647
How often do you change out your air filter?
The thread title really says it all.
"Vegetarians are the enemy of everything good and decent in the human spirit." -- Anthony Bourdain
Promote skepticism and critical thinking. www.randi.org
JLam is offline
Old 11-30-2006, 04:52 PM   #2 (permalink)
Corey's Avatar
Member Number: 2902
Re: How often do you change out your air filter?
Supppose to be yearly I think.
This is what I am doing.
I ran the stock filter from July the 24th (pickup day) until Octover 14th on my first outing.
It was very dusty up there where I go.
A few days later I pulled that filter out and put in a brand new one.
Next time I head out on a trip to the hills again when it is dusty, the old filter will go back in since it is already a little dusty.
Then when I get back the clean one goes back in.
But I think once a year is good.
And I will only run the stock Toyota one.
The ones you oil if you over oil them they can screw up your TPS.
I prefer the Toyota stock filters.
Corey
2007 FJ Cruiser
ARB bumper, Warn XD9000, OME lift, snorked, penthouse, to much to list, see my website & buildup thread
YotaTech | My Website | My Rigs Build-Up | My Penthouse | Video Of My Penthouse | Camping Gear Reviews | Rehinging Your ARB/Engel Fridge
Corey is offline
Old 11-30-2006, 04:58 PM   #3 (permalink)
Moderator
opg4759's Avatar
Member Number: 2775
your supposed to change them?
I put the TRD filter in mine. As Corey said too much oil will mess up the TPS, just don't oil them like female oil wrestler and you will be fine. I clean mine every 5K, unless I'm somewhere it's really dusty then I clean it after the trip.
NUFC
Rig
Black Diamond M/T,Custom XM Inno mount ,Bandi antenna mount/ Yaesu FT-7800r, 4 Piece Budbuilt Skids(still need the gas tank skid), OME 886/895, All-Pro upper and lower links, Procomp 7089, Procomp Extreme M/T's, Project Overkill rails,
Gear
Home Brew
Project Overkill
Always trust the Gene Genie
opg4759 is offline
Old 11-30-2006, 06:36 PM   #4 (permalink)
frogeye's Avatar
Member Number: 6849
opg4759 previously said: View Post
I'm using the TRD filter too. I plan to clean it each oil service (every 5k) and right after any real dusty days out on the trails.
Chris | My FJ El Froggo
www.frogeyesprite.org
Save The Cactus!!!
frogeye is offline
Old 11-30-2006, 06:53 PM   #5 (permalink)
White Rim's Avatar
Member Number: 3435
If I spend a lot of time in dusty areas I will do it more often, but with less than 7K miles on the rig it does not seem that it would be an issue yet.
White Rim is offline
Old 11-30-2006, 11:38 PM   #6 (permalink)
BLK PUG's Avatar
Member Number: 7770
Whenever it starts looking way too dirty? Uh, I've used K&N air filters, and I don't even bother with cleanings and re-oiling anymore. I think at around 50,000 miles or extreme dirtyness, whichever comes first, I just toss in a new one. Tap out the bugs and rocks whenever you check it. Do the cleanings and re-oiling if you are capable of the patience. I've done it, but it seems that so much time passes in between, that buying a new filter at that point is worth it. I'll have to see with the FJ. I just dropped in the K&N at 1K miles with more than half of it being off-road, the paper filter was just a little tan. There were small pebbles and some dirt pre-filter, which I just shook out. I don't expect to have to "tap-out" the K&N filter til around 10,000 miles, then just pop it back in.
This ain't no Taco, it's a Burrito!
BLK PUG is offline
Old 12-04-2006, 12:05 AM   #7 (permalink)
ididntdoit5150's Avatar
Member Number: 5242
Send a message via AIM to ididntdoit5150
i clean mine after about every other time off road just because i dont like the idea of using a dirty air filter, plus it is a K&N so it is really easy to clean.
BLK PUG - check it, i bet it will look disgusting. mine always looks almost black on the intake side.
( O TOYOTA O )
THE FIRST EVER FJC COMMERCIAL!!!!
P.S. - the BD FJC wheelin in the first like 8 seconds with the tinted corner lights.....yeah.....thats me
MY CUSTOM FJC A.K.A. "K.I.T."
ididntdoit5150 is offline
Old 12-04-2006, 09:14 PM   #8 (permalink)
BLK PUG's Avatar
Member Number: 7770
The Pug's paper nose is clean after 1004 miles. The Pug went to the sticky K&N nose hairs at that point. It's now at 1300 plus miles. I really feel no need to check the K&N filter until my next oil change at 3K miles. I did spend more time offroad than usual too, with the paper filter. Must be the way I drive. I like to go slow offroad, and enjoy the scenery. I also like to avoid body/suspension damage. The paper filter has been through; A favorite no-name Mojave OHV area, Afton, through the soft sand portion at the start of The Mojave Road (I had to go faster there to plane above the sand, or get stuck), Mule Canyon, Last Chance Cnyn, and Red Rock Cnyn which connected back to Last Chance where I exited.
I have attached a picture of the factory paper filter at 1004 miles. My TRD did not come with the TRD air filter, which my salesman read off to me as he was doing some research before I purchased. I suspect some do in less restrictive areas other than California.
BLK PUG is offline
