Old 12-31-2006, 02:55 PM   #1 (permalink)
fjTeddy's Avatar
Member Number: 4051
Greasing u joints & shafts
After 20000K I greased the u Joints & shafts.
The joints took 2 or 3 pumps of the gun, but the shaft zerts at each end of the transfer case took about 50 pumps before grease came out.
Did anyone notice the same thing or please have them greased.
Love my fj
fjTeddy is offline
Old 12-31-2006, 04:03 PM   #2 (permalink)
INI SLDR's Avatar
Member Number: 3699
Re: Greasing u joints & shafts
Just curious, does pumping them until grease comes out break the seal and let water and contaminents in? What grease did you use? I wanted to grease mine but wasn't sure if I should pump out all the old stuff or not...
"How are the roads today?" she asks.
" Its winter in Alaska, thats how the roads are. "
INI SLDR is offline
Old 12-31-2006, 04:53 PM   #3 (permalink)
Gwagg's Avatar
Member Number: 834
I thought, but could be wrong, the grease for the U-joints and propeller are different? I might have read that in the manual??
It is not the size of the man's truck but what it can do!
TLCA #8867
Gwagg
2007 FJ - Voodoo Blue
Savage 25
Gwagg is offline
Old 01-01-2007, 11:46 AM   #4 (permalink)
1911's Avatar
Member Number: 4994
fjTeddy previously said: View Post
Whoa there, WAY too much grease in the slip joints! They only needs two or three strokes of the grease gun at most. Filling the slip joints full can cause them to hydraulically lock, which will transfer undue stress to your drive line when it needs to contract. That's why they're slip joints, so they can expand and contract as needed. By filling them full you will negate their function.
Gwagg previously said: View Post
The FSM specifies Lithium-base chassis grease (NLGI #2) for the single u-joints and Molybdenum disulphide Lithium-base chassis grease (NLGI #2) for the slip joints and the double u-joints. IMO this is an unnecessary distinction; Moly-fortified Lithium grease works great for both and harms nothing even when it is not specified. The key here is the NLGI #2 standard (like the API standards for motor oil).
I buy Amsoil synthetic heavy-duty extreme-pressure Moly-fortified grease AMSOIL - Synthetic Heavy-Duty Grease, NLGI #2, GC/LB and use it in every application in all my vehicles - wheel bearings, steering knuckles, drive lines, chassis, etc.
KE5VTE
TLCA # 16550
All men dream: but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men, for they may act their dreams with open eyes, to make it possible - T. E. Lawrence
1911 is online now
Old 01-01-2007, 01:21 PM   #5 (permalink)
INI SLDR's Avatar
Member Number: 3699
Question Re: Greasing u joints & shafts
So do you just give 2-3 pumps and then leave it or do you pump until the old stuff starts coming out from under the caps???
INI SLDR is offline
Old 01-01-2007, 02:52 PM   #6 (permalink)
SupraTuRD's Avatar
Member Number: 7943
Send a message via AIM to SupraTuRD Send a message via Yahoo to SupraTuRD
How does the Mobil 1 synthetic grease compare to the amsoil stuff?
Mobil 1 Synthetic Grease
SupraTuRD is offline
Old 01-01-2007, 03:02 PM   #7 (permalink)
1911's Avatar
Member Number: 4994
INI SLDR previously said: View Post
Just to make sure we're both on the same page, there are two different kinds of things to grease on the FJC, the u-joints and the slip joints.
The u-joints are wear items that take a beating every time you drive, hence it's very important to make sure they're always greased - so yes, every oil change (or more often if I've been wheeling, under water, or just driving in a lot of bad weather) I grease all the u-joints until I can just barely see grease seeping out from under the bearing caps. No need to get too happy with the grease, but if you see a little coming out then you know the needle bearing is full. You don't need to replace all the old grease (unless you see water coming out too), just make sure they are full of grease.
The slip joints are not wear items in the same sense as the u-joints; there are no bearings in them, they only need to be able to expand and contract fore and aft a little bit and the splines take all the torque applied to them. As mentioned before, filling them with grease can lock them up, so only apply a token couple of pumps with grease gun just to put a little bit in there. You don't ever want to see grease coming out between the inner and outer slip joint.
KE5VTE
TLCA # 16550
1911 is online now
Old 01-01-2007, 03:05 PM   #8 (permalink)
White Rim's Avatar
Member Number: 3435
2-3 squirts into the ujoint zerks is about right. You can wait till you feel resistance and then slow down until you feel resistance see a tad of grease coming out the spider seals, however this runs the risk of blowing out the spider seals. No need to pump out the old grease.
The shaft zerks should just get 3-4 pumps max.
If you pumped the space behind the shaft splines full of grease you may want to consider removing that grease or at least some of it. It is incompressible and will not allow the shaft to move beyond the point where the grease completely fillls the volume behind the shaft splines. Result will be blown shaft seal.
White Rim is offline
Old 01-01-2007, 03:09 PM   #9 (permalink)
1911's Avatar
Member Number: 4994
SupraTuRD previously said: View Post
It's good stuff; I used to use it before switching to Amsoil. The main reason I switched to Amsoil is because I can get all my synthetic lube products in one place and in bulk volumes with them. If it's important to you, the Mobil 1 grease is not advertized as moly-fortified, but that doesn't bother me, it's quality stuff and I'm sure it has a good additive package.
KE5VTE
TLCA # 16550
1911 is online now
Old 01-01-2007, 05:12 PM   #10 (permalink)
White Rim's Avatar
Member Number: 3435
i use a sta-lube moly disulfide lithium graphite grease
the molybdenum metal plates out onto the bearing surfaces creating a corrosion barrier
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
bugs1961
