I have a Nissan Titan and a 350 Z. Both have benefited from a trip to the dealer and a 2 degree advance in the timing. Has anyone tried to advance a FJ? If so, what were the results. It only takes 30 seconds to do, and with my titan I gained between 10 -12 HP. I only gained 3 or 4 in the Z. This is a huge topic in a Titan forum, and everyone that has done it has seen a power and torque increase.
"See Warriors, see what you get when you mess with the Orphans?"
I set most of my other vehicles a little advanced, but haven't fiddled with the FJC timing while it's still under warranty. Most factory timing is very conservative and it does help to advance it.
N5MUD 4x4ham.com
TLCA # 16550
High Desert Cruisers
Don't forget advancing the timing will not have much benefit unless you have the octane to support it. It is likely Toyota was already fairly agressive here since the recommended using premium in the first place to get the HP numbers they claim. I am not saying there might not be more to be gained but if you ever had to run lower octane you might get a fair amount of pinging until the ECU recalibrated itself.
6MT - After enough repetition, even the wittiest signature becomes boring.
On the Nissans you can use the Consult I, II, or III to advance it through the PCM/ECM.
*If* you could do it manually and make the ECM accept the change, you would do it through the C.A.S./C.P.S. (Crank Angle Sensor or Crank Position Sensor) which is effectively tells the PCM where the valvetrain is in it's cycle and ergo, when to fire.
It's just a Hall Effect sensor utilizing a magnet and a pin.
Most engines have a range of acceptable initial ignition advance. Like for example 15 degrees BTDC with a +/- value or range of 2 degrees.
If that's the case, depending on the ron/mon value of gasoline you have available, you could possibly set the timing to 17 degrees *if* you use 93. (Advancing it 2 degrees beyond the factory spec)
If you live in Cali and only have 92, it would be prudent to stay with 15 or 16.
colnajoe's point is, if OE spec is, say 13 because of standard production variances, and you're running, say, 93, as 1911 states, you're not taking advantage of the higher octane (slower burning) fuel that the advanced ignition would utilize to make more power bottom end and midrange.
I don't give a fat baby f_ _ k about top end power on this application, I want bottom end and midrange grunt, and as much as I can get within reasonable parameters of the original design.
I would, however, reduce it to the bottom (13) or at most, midrange (14) of OE design when supercharging, providing there's not a replacement ECM with the upcoming blower. Even then, I would only want it *exactly* at OE specs.
Again, sorry for such a long post.
If anyone knows how we can adjust the timing, please chime in here. TIA
FWIW, I haven't researched what the spec timing is on this engine, I'm just using 13-15 as an example. That example is for a Nissan SR20DE(T)
A fellow Silvia fan? Good to know another. I still miss mine sometimes.
