Old 03-22-2007, 04:34 PM   #1 (permalink)
Has He Lost His Mind?'s Avatar
Member Number: 4663
Stp
Do those gas treatments, octane booster, and fuel injector cleaners from STP really work? My neighbor uses it all the time. He probably spends $20 month on them.
Has He Lost His Mind? is offline
Old 03-22-2007, 04:37 PM   #2 (permalink)
mikey's Avatar
Member Number: 2806
Re: Stp
If you use fuel injector cleaner make sure it is one that doesn't contain alcohol. The alcohol will cause problems with o-rings and seals.
mikey is offline
Old 03-22-2007, 04:38 PM   #3 (permalink)
Sharkbait's Avatar
Member Number: 8374
Send a message via AIM to Sharkbait Send a message via MSN to Sharkbait Send a message via Yahoo to Sharkbait
Re: Stp
Has He Lost His Mind? previously said: View Post
this is just me, but i find those useless, i think its just something someone uses to feel good that they're taking care of their car. a small amount feelin good bout themselves. but, thats just me.
gotta love it....
Sharkbait is offline
Old 03-22-2007, 08:27 PM   #4 (permalink)
Mustang's Avatar
Member Number: 6616
Re: Stp
It might be usefull if you had some poorly formulated gas while traveling in the thrid world. I can't think of much use in the USA.
Mustang is offline
Old 03-23-2007, 06:45 AM   #5 (permalink)
Shiz's Avatar
Member Number: 3261
Re: Stp
i dont think they work too good either. most of the junk they sell
my jury is still out on the oil additives though. Prolong, lucas etc...
Shiz is online now
Old 03-23-2007, 09:09 AM   #6 (permalink)
BDFJ's Avatar
Member Number: 6261
Re: Stp
El Crappo. Stand back from the Magic Potion table! Walk away. Do not turn around. Put your wallet back in your pocket and leave the store.
Buy good gas (Chevron or 76), use good oil, keep air cleaners clean, follow maintenance schedules and you'll be good for 200k miles and more.
-Jim
NorthWest FJ Cruiser Club <<— NEW PRIVATE FORUM ONLINE!!!
PDXTuning Dyno Pull
Purchased: '07 BlackDiamond AT · UR2 · CQ · GY · C7 · EL · Skids · Sills · Rubber Mats
Aftermarket: 265/70R 17 BFG ATs · Trail-Gear Sliders · FormFit Hood Protector · Matching Tint · AVS Visors · Dual PIAA Horns · ScanGauge II · Schrader's Flag Mount & Tri-Mount · BandiMount · Galaxy DX 45MP CB with Firestik II
Mods: Lucrum Winch Mount & Warn M8000 — OME 3" Lift
TRD Stuff: Exhaust · Cold Air Induction
BDFJ is offline
Old 03-23-2007, 01:02 PM   #7 (permalink)
Kansas Law Dog's Avatar
Member Number: 931
Re: Stp
STP appeared on the scene in the mid 1950's and provided an engine oil that probably was a cut above the general dino oil back then. The number of refiners producing lube stock (to make dino oil) has consolidated many fold over the same period. Tighter product specifications and quality control have made dino oil a product you can rely on. Also, there is synthetic lube oils that have even narrower specifications, but I feel that changing dino oil every 3000-5000 miles (including a new oil filter) is adequate engine protection.
In the late 1960's high octane gasoline contained lead and lots of gum forming olefins. Improvements to components that make up gasoline, removal of tetra-ethyl-lead, and better stability additive packages have made significant gains in the last 40 years. All gasolines sold in the US and Canada have good generic additives, and if you like marketing hype, the majors make claims that there gasoline is superior.
There may have been a time that STP offered a product better than the general industry, but I think the gap has closed and STP no longer stands out from the crowd. Sometimes advertising does wonders for sales.
Kansas Law Dog is offline
Old 03-23-2007, 02:01 PM   #8 (permalink)
bartt's Avatar
Member Number: 1660
Re: Stp
Maybe this is coincidence but I doubt it..
Years ago I had an old nissan that was burning some oil, so I started putting STP in it. That seemed to help with the burning. After a while I changed the oil and did not have any stp to put in. When I started it up after that, these was some knock in the bottom end, when it never did that before.
Like I said perhaps it was coincidence, and it was an old car, but I have never used additives since that experience.
My 2 cents..
bartt is offline
Old 03-24-2007, 10:36 PM   #9 (permalink)
Razor J's Avatar
Member Number: 4495
Send a message via MSN to Razor J
Re: Stp
I've got a good friend in the gasoline business and we have hit this topic before. The major companies differ in their product only by their additive packages. These additives will help keep injectors clean, etc. All majors pretty much have the same additives from a chemical composition standpoint. If you don't use anything but fuel from Bob's petrochemical, you could have some problems with lack of detergents/ cleaning agents but major brands will not require additional additives.
Razor J is offline
