As many have posted under cleaning topics, I've learned that not all dash/plastic/leather treatments are equal. I'm hoping to get some similar input on fuel additives. What do you guys use for fuel system cleaners?
I purchased Champions Complete Fuel System Cleaner (valves, injectors, combustion chamber) "Powerful Synthetic Formula"
Any thoughts objections? There's quite a price difference between some of the brands available and I just want to use the best there is, and not always is the most expensive the best product out there.
"I'd like to die in my sleep like my grandfather. Not screaming in terror like the passengers in his car."
Have you put on enough miles to warrent it?
Are you running bad gas?
Any signs or symptoms of performance loss or issues?
Just curious why you are looking at something like this?
Having come from a high performance background with street rods, road racing (completed in the Silver State Challenge and Pony Express in Nevada...modern Cannon Ball Run)...built blown big blocks and TPI small blocks....well I liked getting more octane but switching fuel is best for that...
If storing long term then a stabilizer works but not sure if the injector cleaner stuff works that well.
Oh well I look forward to the greater minds than mine chiming in..
enjoy,
1leglance
KE7NKP
Disabled Explorers
Helping the handicapped independently access the backcountry www.disabledexplorers.com
Voodoo Blue driver, night nurse, cigar smoker & all around happy camper
Lance, I just hit 15k on my vehicle, I don't run the highest octane gas all the time, and since I'm doing another oil change I had engine performance/cleanliness on my mind. The impulse grabbed me and I picked up some additive. No real engine performance issues, I just know that as a rule of thumb, preventative treatment is better/cheaper/easier than symptomatic treatment.
Do you still think I shouldn't use it?
I use berryman chemtool for injector cleaning every once in a while. However, be warned....this stuff is hard on seals....don't over use it. Also, put it in your tank about 1 tank before you plan to change the oil. All the crap that's coming off the injectors is deposited in your oil, so change the oil when you've burned up that tank.
I use Chevron's Techron additive, available at my Costco. I only use it at oil change time. my $.02
Sun Fusion 4WD AT, UR, Roof Rack (C7), Rock Rails, TRD Exhaust, BFG AT KO's
'06 Super White Tacoma PreRunner AT, Dbl Cab, Sport, TRD Exhaust, SnugTop, Westin Step Bars, Toyo Open Country AT's
HTH,
Sean
I'm headed to Tucson Sunday, so I'll make sure I drop it in tomorrow and change the oil when I get back. That's something I never thought of. Good info.
What are you going to do here? I would be happy to direct you to some good wheeling if you are interested. LMK.
