Old 07-25-2007, 11:35 AM   #1 (permalink)
david5272's Avatar
Member Number: 10894
Check Oil Level
Hey this sounds strange...but how do you check your oil level?
My engine only have a cap....no dipstick.
david5272 is offline
Old 07-25-2007, 11:42 AM   #2 (permalink)
JAXTOY's Avatar
Member Number: 11799
Re: Check Oil Level
Dip stick on left side of motor, (looking at motor) under plastic air intake tube.
JAXTOY is offline
Old 07-25-2007, 11:46 AM   #3 (permalink)
1911's Avatar
Member Number: 4994
Re: Check Oil Level
david5272 previously said: View Post
Bolted to the engine block right at the front of the passenger-side valve cover is a narrow tube with a 1" (guesstimate) bright yellow plastic ring on the top. The yellow ring is the handle for the dip stick; pull it up and the dip stick out to check your oil. If the yellow ring and hence the dip stick is not there, the last idiot to change your oil must have forgotten to put it back in, and there will probably be oil and dirt all over that side of your engine compartment.
KE5VTE
TLCA # 16550
All men dream: but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men, for they may act their dreams with open eyes, to make it possible - T. E. Lawrence
1911 is online now
Old 07-25-2007, 12:53 PM   #4 (permalink)
RMGST's Avatar
Member Number: 9608
Re: Check Oil Level
Before you ask the next question, there is no dipstick for the transmission.
RMGST is offline
Old 07-25-2007, 01:02 PM   #5 (permalink)
FamilyJ's Avatar
Member Number: 8764
Re: Check Oil Level
Per the owner's manual, unscrew oil cap and insert index finger. Anything under a two-knuckler means you're a quart low...
#7751, Titanium Silver, Manik nerf bar w/Rock Rails, ScanGuage ll, Manik Tail Light Guards.
FamilyJ is offline
