OK... I have it installed sounds great on the street. when Im on the HWY and I put my foot in it, it has a slight vibration somewhere on the passengers side... Everything is tight, nothing is loose...
Anyone have similar issue...? Any suggestions...
thanks in advance
ARB RR, UPG-1, OME H_Frt/M_Rear, ProComp 1069's, ProComp Xtrm AT305/65/17's, TRD Exhaust, AFE Cold Air Intake, Demello Sliders, BUD BUILT SKIDS
more to Follow...
I have the same vibration noise on my FJ also. I don't think it is the intake itself. I think it is the intake causing a vibration in the dash, either transmitting it from the airbox through the fender, or maybe sound waves from the intake causing the rattle? It doesn't bother me so I have not really spent much time looking into it.
__________________ 2007 TITANIUM METALLIC 4X4 6MT
ROCK RAILS/PAINTED SPARE TIRE COVER/A-TRAC SWITCH/TOYTEC FJ3-FRCC LIFT/MICKEY THOMPSON 265/70R 17 BAJA MTZ TIRES/FLOWMASTER 40 SERIES MUFFLER/AFE COLD AIR INTAKE/ELLIS BATTERY CLAMP/ALL PRO IFS & TRANSMISSION SKID/URD SHORT SHIFTER/ELLIS DOM MOUNTS/LUCRUM WINCH MOUNT/MILEMARKER SI9500
I will soon be off again...The mountains are calling, and I must go.
Thats the sound of gasoline going adios! Mine does the same thing.
"It is better to die on your feet than to live on your knees." ~Emiliano Zapata~
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ 07 4x4 auto VooDoo - My Fj Supermotors Link -
Also, be sure to check the hose clamps on the intake tube flange after your first day of rough offroad driving. Mine came loose and caused the check engine light to come on.
more to Follow...
I have had my aFe on for about three months and I have not noticed a vibration. Perhaps I should listen or feel for a vibration the next time I take my FJ out for a spin.
__________________ '07 Voodoo Blue/6MT/Upgrade #1 Package/Roof Rack/Towing Package/ALL-PROMods: Front Bumper w/Prerunner Light Bar, Rock Guards, Full Skid Plates, High Clearance Exhaust, Ultimate Lower Skids, Shock Skids/aFe Pro-Guard 7 CAI/KC Daylighters/BFG AT/KO's285x70x17 Tires/Magnaflow Exhaust/Man-A-FreExtended Brake Lines/Power Tank/ManikTaillight Guards & Roof Rack Light Bar/SWAY-A-WAY Coil-Over Suspension/Light Racing Adjustable UCA/Safari Snorkel, SCUBA Mods+ a butt load more mods..
thanks in advance
I had the same problem, The new airbox is close to the bottem, I changed the rubbers under the airbox for bigger ones. Now I have more space under the airbox.
