Old 08-21-2007, 09:18 AM   #11
Kansas Law Dog's Avatar
Member Number: 931
Re: Fuel Filter..is it hard to get to and change?
No just one in the tank. See images.
fuel-filter-hard-get-change-fuel-1.jpg  fuel-filter-hard-get-change-fuel-2.jpg  fuel-filter-hard-get-change-fuel-3.jpg
Kansas Law Dog is offline
Old 08-21-2007, 09:22 AM   #12
Banned
Member Number: 8863
And I assume there's no access from above...ya gotta drop the tank?!
I miss the old daze....
NYCTRD is offline
Old 08-21-2007, 09:26 AM   #13
Member Number: 931
NYCTRD previously said: View Post
Yeah, the procedure to drop the tank is listed in the Fuel section of the factory manual.
Old 08-21-2007, 11:16 AM   #14
Banned
Member Number: 8863
Seems like adding an inline filter would be a good idea--like a big oil can sized Bosch or some other heavy duty filter designed for higher pressure fuel injected systems.
Then a blast of Techron every 5 to 10-k.
NYCTRD is offline
Old 08-21-2007, 12:09 PM   #15
gunner5355's Avatar
Member Number: 12101
NYCTRD is right make sure it is for fuel injected vehicles not just one that you clamp in place with gear clamps. Check summit or even your local parts store. with some stainless (I perfer brass could work too) fittings, tubing (3/8??) and a common GM fuel filter (wix 33481) you could install on the frame between the engine and the tank. If you do so make sure the system is depressured prior to starting. There are systems out there you may have to check around, parts stores, mechanic shops, aguraculture or heavy implament dealers too. Stay away from the Canadian Tires and Generic store. If they sell lumber, plants and auto parts they may not know what your talking about. Hope this helps
The boys and I want you to have this, it's a little momento, it's a Chiefs key ring, you can buy these in stores.
4 KC LIGHTS ON STALLION ACCESSORIES LIGHT BAR
3" ROUGH COUNTRY LIFT
285 70R 17 Pro Comp Severe Weather AT's
Airaid Intake
gunner5355 is offline
Old 08-21-2007, 12:28 PM   #16
RMGST's Avatar
Member Number: 9608
Actually, there is access to the fuel pump assembly from the top, under the rear seats. I am not sure if is enough to be able to pull the pump assembly out and replace though.
RMGST is offline
Old 08-21-2007, 01:22 PM   #17
Banned
Member Number: 8863
Hey-It's all about keeping your "precious bodily fluids" clean!~
I've never owned a vehicle without a friggin' fuel filter (the in-tank filter can't be much more than a fine screen)...
These annoying little ommisions (like a dipstick for the AT, lack of a higher rear breather, etc.) are absurd for a vehicle positioned as "rugged".
I'm moving to Austrailia!
NYCTRD is offline
Old 11-17-2007, 07:43 PM   #18
FJ Expeditions R Us
w5wi's Avatar
Member Number: 11734
I remember that there were some screens in funnels that would trap water from fuel. I wonder if there is a similar screen that could be placed in the filler neck?????
cheers,
dale
Happy Trails!
TLCA #17625
LOS TRES AMIGOS IN MEXICO
TITANIUM METALLIC--A/T
ARB Bumper - Warn Winch - OME Heavy 886/895 - Bandi Mount - All-Pro Lower link skids - Bud Built skids - Snorkle - Toyota prefilter (cyclone air filter) - Optima Yellow Top Battery - Painless Dual Battery Control System - Scuba Driver Mod - Kenwood DNX 7120 GPS - A-TRAC mod - 110v add-on - Rock Rails - Rear Locker - Roof Rack - BFG TA/KO's - ARB Fridge/Freezer - '08 side visor mod - Royal Purple fluids - E3.68 Spark Plugs - All Pro Rear Bumper - All Pro Lower Links - M-Pac rear and side mounts - AT Cooler
To be continued...
w5wi is offline
Old 11-17-2007, 08:19 PM   #19
NBFJCruz's Avatar
Member Number: 15365
This is my third Toyota 4x4 and sold the first two at 8 and 9 years old with over 450,000kms (approx.270,000mi)on each. I can honestly say I never changed a fuel filter. The filter on the 2.7 ('98 Tacoma) was the size of a large oil filter with high pressure banjo fittings at either end that was bolted to the side of the block...My local mechanic said he had never even heard of one needing changing.....Let's hope that Toyota has the same engineering ideals in mind for this set up.
'07 FJ, C package, 5A, Ti
mods so far
Mod, mod, and more mods and it still looks way to friggin' stock.....grrrrr
Love my truck.....Love my forum
FJ spoken here
http://www.fjnortheasters.org
The Northeastest Northeaster is in need of new tires and I will be getting them from http://www.discounttiredirect.com/
NBFJCruz is offline
Old 11-17-2007, 08:36 PM   #20
Toyota Pete's Avatar
Member Number: 3371
My 1st Toyota 91 EXT CAB 4WD 205,000kms never had to change fuel filter.
Toyota Pete is offline
