Old 08-18-2007, 10:06 PM   #1
Mikeys07FJ's Avatar
Member Number: 6415
Fuel Filter..is it hard to get to and change?
I searched but didn't see anything right off about where the fuel filter is located, what the part number is, and if its hard to change?
Does anyone have any input?
Thanks
[Titanium MT6 4X4
Mikeys07FJ is offline
Old 08-18-2007, 10:30 PM   #2
MudLovingFJ's Avatar
Member Number: 8945
Send a message via AIM to MudLovingFJ
Re: Fuel Filter..is it hard to get to and change?
great question, i have been wondering the same thing for a while now
Do it right the first time or don't do it at all.
ICONs/35s/Demello
The So-Cal Safari Snorkel Install Guy 11 chicken necks installed to date
STAY TOGETHER YOU HUMPTY-DUMPTY OF A TRUCK!
MudLovingFJ is offline
Old 08-19-2007, 10:08 AM   #3
VooDoo FJ's Avatar
Member Number: 8218
I believe that FJ's have a non-servicable fuel filter.
2007 FJ MT6||OME 885/895||Firestone Destination 285's||K&N Air Filter||OEM Rock Rails||All-Pro Extreme LCA's, Trailing Link Skids, High Clearance Exhaust||TRD Quick Shifter||Demello Hi-Lift Mount
TLCA #18077
N.C. Beach Buggy Assoc. #12893
TTORA #13074
NRA #149022131
VooDoo FJ is offline
Old 08-20-2007, 12:28 PM   #4
gunner5355's Avatar
Member Number: 12101
That must mean in the fuel tank with the pump and sending unit?
The boys and I want you to have this, it's a little momento, it's a Chiefs key ring, you can buy these in stores.
4 KC LIGHTS ON STALLION ACCESSORIES LIGHT BAR
3" ROUGH COUNTRY LIFT
285 70R 17 Pro Comp Severe Weather AT's
Airaid Intake
gunner5355 is offline
Old 08-20-2007, 12:32 PM   #5
Member Number: 6354
Mikeys07FJ previously said: View Post
Thanks
Do you feel you need to change it? Most vehicles today have non servicable fuel filters in the tank wiht the pump assembly. My last vehicle had one of these and provided over 160K miles of service for 11 years with no issues. Run it!
mikesfj is offline
Old 08-20-2007, 12:40 PM   #6
Member Number: 6354
To answer your question, It requires removal of the fuel tank, removal and disassembly of the fuel pump/filter/sender assembly. It is doubtful that the filter is available as a seperate unit so cost will be steep.
mikesfj is offline
Old 08-20-2007, 10:14 PM   #7
Mikeys07FJ's Avatar
Member Number: 6415
No, I don't feel the need to change it. I just know that changing the fuel filter at certain maintenance intervals has been routine with past cars that i've owned. I assumed as much with the FJ.
[Titanium MT6 4X4
Old 08-21-2007, 07:57 AM   #8
VooDoo FJ's Avatar
Member Number: 8218
mikesfj previously said: View Post
I believe that you are correct, you have to buy the fuel pump assembly.
TLCA #18077
TTORA #13074
NRA #149022131
Old 08-21-2007, 09:02 AM   #9
Banned
Member Number: 8863
Do ya think it would be a good idea to put a big, quality in-line filter somewhere?
Kind of surprising a vehicle designed for off-roading and harsh conditions doesn't have a replaceable fuel filter...or an AT fluid dip stick.
The in-tank filters are kind of a last resort particulate filter...
This is my forst Toyota & I realize the FJ is more a utilitarian vehicle, but from the previous Hondas & Subaru's I've owned (all bought new) those manufacturers alway's seemed to think of "the "little things"...is this "par for Toyota's course"??
NYCTRD is offline
Old 08-21-2007, 09:03 AM   #10
Banned
Member Number: 8863
PS: Does the FJ have TWO pumps (one in tank, one external)?
NYCTRD is offline
