Old 08-21-2007, 01:28 PM   #1 (permalink)
Singha's Avatar
Member Number: 12233
What do you think, Amsoil Oil PreCharger.
Friend and I where talking shop, and he mentioned this item that Amsoil has
AMS-Oiler™ Oil Precharger I was very interested. Since most of the engine wear is done upon start up I figure this will build oil pressure and providing vital lubrication prior to starting.
What do you guys think? Anyone run one or ever have?
Also where would I be able to hook this up too for the oil return? I was going to supply the oil to this unit using a oil sandwich plate like this one oil Sandwich plate (Would rather have one from Toyota, like the one from the TRD supercharger) this will also provide a hook up for a oil pressure sensor for a oil pressure gauge I plan on installing.
Kinda pricey at $400 bucks. I think it is worth it since I am planning to keep my Fj for some time.
TLCA#18914
GCLC#2083
NYC
Ti 6sp. CQ GY UP C7 37 2Q.
ADDED 6D(x2),EL,V5,WL(x2).
SE Speced PLUS/TRD CAI,Q/Shift,Raditor Cap,JDM TRD gas cap cover.
MODS
AllPro Sliders,E-Locker+Diff skid,R-LCA,Bandi,Digger R-UCA,OME 883+TP14(w/TRDs),Rear AirLift airbags,Rasta Skid plates,TC A-Arm Skids,Lucrum mount WO/winch.
Hella horns,Husky mats,SGII,Osram SilverStar,OEM Brush Guard w/Hella 500FF,LightBar w/ 4 Hella FF50,
Dave Crums NEW Rear Trailing Arm MOUNT.
Singha is offline
Old 08-21-2007, 02:02 PM   #2 (permalink)
DEWFPO's Avatar
Member Number: 7505
Re: What do you think, Amsoil Oil PreCharger.
The engine in the FJ should last at least 300,000 miles with reasonable maintenance and no Pre-Luber. I run synthetics and excellent quality filters to better my chances. Never felt the need for a pre-luber in any of the vehicles I maintain and I'm fairly anal about that stuff, althought I do understand the premise and think it is a great idea (especially on a -20F morning, or one that sits for weeks at a time).
DEWFPO
"Enjoying the Journey"
DEWFPO is offline
Old 08-21-2007, 04:37 PM   #3 (permalink)
Singha's Avatar
DEWFPO previously said: View Post
DEWFPO
And a block heater would be perfect for those -20F.
TLCA#18914
GCLC#2083
NYC
MODS
Singha is offline
Old 08-21-2007, 04:41 PM   #4 (permalink)
DEWFPO's Avatar
Member Number: 7505
I've got a block heater in the FJ but it's pretty weak. Only 400 watts and only on one side. Better than nothing, but not optimal by any means. There is room on the other side to put one in but no hole is drilled. An oversight by Toyota in my opinion.
DEWFPO
DEWFPO is offline
Old 11-16-2007, 08:21 AM   #5 (permalink)
breauxtus's Avatar
Member Number: 10906
Hey guys.
I just took a look at the AmsOiler/PreCharger. The specifications indicate it's only good to about -30F. I live in the mountains of Colorado where my vehicle sits outside every night. Many nights during the winter, the FJ endures temperatures of -40F - -30F with winds in excess of 80mps being fairly common.
I wouldn't mind the PreCharger, but am not sure whether it would burn the pump with too many starts below -30F. I submitted a question to Amsoil on the issue and will post the answer once I receive it.
I like the fantasy of getting 300,000-500,000 miles out of the Foxtrot Juliette.
Hopefully, this PreCharger can contribute!
Regards,
Mike
YinYang
2007 FJC
They call me The Nukldragr!
breauxtus is offline
Old 11-16-2007, 08:41 AM   #6 (permalink)
DEWFPO's Avatar
Member Number: 7505
breauxtus previously said: View Post
Hey guys.
Regards,
Mike
Hi Mike,
I have a similar situation although I occassionally see -20F and the FJ sits outside as well. I installed the Toyota engine block heater, use 5W30 synthetic oil and plug it in to a combination 20F Thermocube and timer. This works fine for me. You may want to consider going to a 0W-30 synthetic oil even with the pre-luber. Mine has been starting up fine but a pre-luber can't hurt. Even using the engine block heater it takes a good while of driving before there's any heat in the cab. If you need to you can get a dual battery kit and install it since there's plenty of room in the FJ's engine compartment. I don't know how much of a draw the pre-luber puts on the battery, but at -30-40F any draw will put a strain on the battery. I have also switched the transfer case and rear diff to synthetic. Super easy and fast.
DEWFPO (about 130 miles west of you).
DEWFPO is offline
Old 11-16-2007, 09:14 AM   #7 (permalink)
Member Number: 6839
Hey guys.
I bet you very very rarely get below -30F. That would be a record low in most months. Wind chill doesn't count. What is your elevation?
06 Taco, 4x4, Auto, DC, TRD Off Road
JohnJerk is offline
Old 11-16-2007, 09:15 AM   #8 (permalink)
Duc Hunter's Avatar
Member Number: 14773
Look for oil pan heaters, drop the pan, add a bung...some may even go in via the drain plug. The issue is simple getting the oil warm enough to pump well. Do I know where to find them............no, sorry. But I know they are out there.
04 4Runner Limited V8, NV, SR, GY, RF, HP, P9, Z1, E5, XM Radio, BlueTooth Wireless, OME Lift 885/896, 285/70/17 (had 265/70's), SpiderTrax Spacers, K&N FIPK, Magnaflow exh, Shrock Bumper, Warn XD9k, Blitz 240 lights
http://www.toyota120.com/forum/showthread.php?t=2156
Duc Hunter is offline
Old 11-16-2007, 09:49 AM   #9 (permalink)
Member Number: 14683
Prelube pumps are commonly used in industrial and commercial applications, especially something like a giant Waukesha V-16. The cost of the motor - hundreds of thousands and up - makes the use of a prelube system a no brainer
If you consistently run winter temps of -30 F and colder, especially the -40 to -50 mark, a "regular" 5W-30 is absolutely a no-no. The SAE J-300 spec only requires a conventional 5W-xx to be "good" to -30 C, or around -22 F, and there is enough standard deviation allowed in the test to put you at risk of increased start up wear. Some oil companies also document this, see page 3 of the following:
http://www.esso.ca/Canada-English/Fi...Xd-3_extra.pdf
I run Mobil 1 0W-20 in my Prius as a "winter" oil, and will next year run it year round. The used oil analysis has been very good with this oil.
Running a 5W-xx oil, my FJ had pretty bad shear. Running Esso XD-3 0W-40, no shear. Put in Mobil 1 5W-20 as a winter oil, will sample soon to determine if there is shear. If the shear is bad, the 0W-40 goes back in
Running a lighter viscosity than "recommended" is fine in bitter cold temps, as the motor will rarely get up to proper operating temp. Oil pan heaters have a lot of application in commercial use, where a motor will run a 15W-40 year round. They're a PITA for cars, unless you're consistently colder than -45 F, run a light synthetic instead.
If you want to do a neat science experiment, put a temperature sender in the back of a V block. In summer, the block will have pretty uniform temp.
In winter, the back of the V block (V6 or V8) will never warm up, especially at -40. I've used mechanical gauges and at -40, even running a winter front, the needle will never move from the bottom peg
jayman is offline
Old 11-16-2007, 10:18 AM   #10 (permalink)
Flappy's Avatar
Member Number: 13407
If you have never been to Colorado in the winter-Fraser, Gunnison, and the San Luis Valley get to -50F/-60F at least once a winter. There have been many a month where you never see positive numbers on the thermometer, just keeping the record straght. The elevation of those places all varies between 7.5k and 9k feet
2007 VooDoo Blue Option Package 2, MT, & ATRAC
TRD Exhaust, Factory Sliders, Skid Plates, Tow Group
Optima Red Top w/quick disconnect
Yakima Load Warrior with Extension
Yakima Bar and Fairing attached to factory rack
FJ Cruiser rocker panel logos and white bezel
Lucrum Winch Mount w/ T-MAX 9000W
Bilstein BE5-C475-H0 shocks
Flappy is offline
