Old 09-04-2007, 07:07 PM   #11 (permalink)
TCao's Avatar
Member Number: 940
Re: AC Condensation Drain Tube Clogged
RocKrawler previously said: View Post
Just wondering if anyone else has had this problem? My FJ has been leaking water onto the passenger side floorboard for weeks, and if you turn the radio off it sounds like there's a fountain under the dash. To top it off now when I hit the brakes or turn left quickly, the fan is hitting the water & sounds like a hissing/bubbling sound. It has been suggested the drain tube may be plugged - anyone familiar with where that is located? Might be a good routiene maintenance item to check for so this doesnt happen to anyone else...
My first guess would be the drain tube is clogged. IIRC, you had removed all your mudflaps. Not having the mudflap on the passenger wheel well may contribute to this clogging?
2007 Ti FJC
TCao is offline
Old 09-04-2007, 07:08 PM   #12 (permalink)
Banned
Member Number: 8863
Perhaps a little screen wrapped around the end (like on in-tank gas lines/sensors) would do the trick...
NYCTRD is offline
Old 09-05-2007, 11:52 AM   #13 (permalink)
jeshua's Avatar
Member Number: 6888
Did you have any luck last night?
Mike Ambs
www.corva.org
- Thomas Paine
Aequitas - Veritas
jeshua is offline
Old 05-09-2008, 02:12 PM   #14 (permalink)
Member Number: 16004
So what was found out on this? Any diagrams? Will the bumper to bumper warrenty cover this to be fixed?
I have the same problem. Water sound and water on passenger floor.
Not sure I understand where drain tube is located. Any help is much apppreaciated. thanks
crr119 is offline
