Purolator - Wix Oil filter question - bypass valve & oversized filters & cold weather - Toyota FJ Cruiser Forum
post #1 of 11 (permalink) Old 11-21-2007, 05:31 PM Thread Starter
Quoted: 0 Post(s)
I've come across an interesting finding when researching which filter to use.
The recommended WIX is 51348.
The recommended purolator PureOne is PL12021.
I've also found that many Tundra owners are using an oversized PureOne (PL30001)
When I look up the specifications of those three filters, the bypass valve specs are :
WIS 51348 : 8-11 psi
PureOne PL12021 : 12-17 psi
PureOne PL30001 : 8-16 psi
Questions :
1. Besides the fact that an oversized filters will require a bit more oil, are there any reason NOT to use an oversized filter?
2. What to make of these bypass valve specs? What setting is specified by Toyota?
3. Is a lower bypass setting better more oil would reach the engine during cold start?
4. Or is a higher bypass setting better because the more oil would be spent going through the filter media
5. Should we be using different filters in cold vs warm weather? For example, in cold weather, use the one with a lower bypass valve setting?
okayfine is offline
post #2 of 11 (permalink) Old 11-22-2007, 05:55 AM
RomaBoy's Avatar
Quoted: 70 Post(s)
Re: Purolator - Wix Oil filter question - bypass valve & oversized filters & cold weather
Wow, you're really into researching oil filters. 1. I had always used the large oil filter in my small block Chevy but in my FJC I'm usig the PureOne PL12021. 2. That I didn't know, whatever the specs call for on the oem filter. 3. That has nothing to do with cold start. Bypass setting is for clog filter. 4. I would tend to agree on that one. 5. Never heard of that one my$.02
RomaBoy is offline
post #3 of 11 (permalink) Old 11-22-2007, 07:43 AM
gunner5355's Avatar
Quoted: 0 Post(s)
Go ahead and use em. Wix acutally had an "Off Road" filter similar to the PureOne offered by Purolator. I'm not sure if it is still available but could check out if your looking to go with each companies best filter.
Question though, why the bigger filter needed? Crumby oil, no air filter, alot of water fording and contaminants in your oil? Swapping filters is usually done because your in a pinch. If the right one is offered why not use it.
The boys and I want you to have this, it's a little momento, it's a Chiefs key ring, you can buy these in stores.
4 KC LIGHTS ON STALLION ACCESSORIES LIGHT BAR
3" ROUGH COUNTRY LIFT
285 70R 17 Pro Comp Severe Weather AT's
Airaid Intake
gunner5355 is offline
post #4 of 11 (permalink) Old 11-22-2007, 03:32 PM
DEWFPO's Avatar
Quoted: 65 Post(s)
As long as it has a good anti-drain back valve you should be o.k. If not, a bigger filter takes longer to fill each start. See my previous post.
http://www.fjcruiserforums.com/forum...ed-filter.html
DEWFPO
Engine Block Heater, '08 Cyclone Pre-Filter, Dual horns, Phillips Osram 70W/65W H4's, RockBlocker and 3M Clear Film, Toyota RearSight Backup Camera, Ultra-Gauge MX 1.3.
"Enjoying the Journey"
DEWFPO is offline
post #5 of 11 (permalink) Old 11-25-2007, 09:08 AM
ReeferMadness's Avatar
Quoted: 0 Post(s)
Its not a big deal really what you use. The Eng never drops below 15psi. No filters are are true "full flow". The only way to catch what bypasses the filter is to use a secondary or "bypass" filter that filters the oil off the main gally and return it to the oil pan. Not worth the install.\
ReeferMadness
ReeferMadness is offline
post #6 of 11 (permalink) Old 11-25-2007, 09:23 AM
FJ Gooch's Avatar
Quoted: 0 Post(s)
Send a message via AIM to FJ Gooch
have you thought about using the toyota oversized filter such as a V8.
i use the toyota V8 filter which part number is #90915-YZZD3
and just use 5.8 to 6 qts of oil. i use the the Lexus 5w-30
hope that helps some
Mods
Scuba / breather
DRL switch
Body mount chop
CB radio with Bandie mount
Fog lights
Pro Comp 6" lift
Pro Comp Extreme Mud Terrains 35X12.5 R18
Lowered front diff
Mods to come
ARB's front and rear 4.56 gears
ARB's fron air locker and compressor
Road Armor front winch bumper with brush guards
and what ever else my credit card can afford
FJ Gooch is offline
post #7 of 11 (permalink) Old 11-25-2007, 10:06 AM Thread Starter
Quoted: 0 Post(s)
Well, the reason I thought it might be better to use the WIX filter in cold weather is that oil thickens up when cold. During cold start, with the WIX filter, the bypass valve would open sooner allowing oil to reach the engine sooner.
okayfine is offline
post #8 of 11 (permalink) Old 11-25-2007, 02:25 PM
1911's Avatar
Quoted: 5 Post(s)
okayfine previously said: View Post
... in cold weather is that oil thickens up when cold.
Use a good quality synthetic oil of the appropriate viscosity and you won't have that problem.
N5MUD
4x4ham.com
TLCA # 16550
High Desert Cruisers
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
1911 is offline
post #9 of 11 (permalink) Old 12-07-2007, 05:22 PM
Quoted: 0 Post(s)
i have read some reviews on oil filters just now and see wix is up there and fram is out. has there been a poll on oil filters? i am going to start changing my own. and looking for highest rated . by fj owners. input? sorry didn't mean to rob a thread
"Why do you carry a 45?". The Ranger responded with, "Because they don't make a .46."[SIGPIC][/SIGPIC]
stringmachine is offline
post #10 of 11 (permalink) Old 12-07-2007, 08:34 PM
1911's Avatar
Quoted: 5 Post(s)
stringmachine previously said: View Post
...looking for highest rated . by fj owners. input?
I use Amsoil Absolute Efficiency P/N EaO57. I also like and have used in the past Mobil 1 and Purolator PureOne filters.
N5MUD
4x4ham.com
TLCA # 16550
1911 is offline
Human Verification
