Old 01-24-2008, 12:44 PM   #21 (permalink)
Mtbcoach's Avatar
Member Number: 2433
Re: Another snorkel installed...
Here are the pics of my snorkel install, I hope PRCruiser doesn't mind me piling onto his thread.
I used the technique advised by Micrad to remove the plastic pins/rivets, a sharp chisel and a bit of force. They were easy to shear off and getting replacements were not that difficult.
Here is the pic of everything marked up and ready to start drilling...
Pic from inside the engine bay with the intake removed...
Pic from inside the fender well with intake removed...
Another view of the same with a bit more in the pic...
Pilot holes drilled, could turn back if I had to...
No turning back now, 105mm hole drilled, easy view into the engine bay...
Major holes finished in the fender, the step drill made these really easy...
Working the burrs off with some 220 grit wet/dry...
Now to apply a bit of the Sun Fusion touch up paint to help hold off the rust...
Plastic nuts installed. This is the one place I would be careful to not round the holes any larger than the spec. Mine went in tight but when I went to install the bracket, they spun in the hole. It took some force to get the to hold, once the screw expanded the plastic enough, they held firm...
A-pillar bracket installed, awaiting snorkel body to be mated with...
AAAHHHH, fits together like a glove, the body installed and mated to the A-pillar bracket...
A couple shots from inside the fender well with everything snugged up...
Time to hack off the intake for the union of the snorkel to the intake. I was careful to not take off too much but found that there is plenty of margin. Due to my paranoia, leaving plenty of material on made for having to really squeeze it back into place. I could have taking off another 1/4-1/2" without any problems...
I chose to hit it with a file to knock off the rough edge and give it a little bevel to make it easier to slip on the rubber union between the snorkel and intake. A few extra minutes made for an easy slip on of the junction...
All done, not bad after all. Can't match the pics of PRCruiser on the beach but it still looks pretty good...
My final assessment of the task is a 3 out of 10 at most. With the right tools, it is a piece of cake. The biggest issue is removing the inner fender liner and using the chisel method makes it easy, you just have to replace the plastic rivets. I bought some from Lowe's home improvement and the did NOT work. They are too big to fit into the holes and when I tried to compress the "legs", the plastic was so brittle, one of the legs would snap off. I'm going to go by the local Autozone to buy the ones there. They are a bunch cheaper than the Lowe's ones (~$1 each) and will follow up with how well they worked out.
The only other hassle is marking the holes for the A-pillar. I did mine alone and it was a bit of a juggle holding trying to get my hand in the right position to mark them with the sharpie. These holes have less tolerance than the fender holes so its important to get them right.
Once all the holes were cut, the actual installation of the snorkel is a quick job. It took me more time to put everything down to take pics than it would have to just put things together. I like the form and fit, it is clearly designed well to fit the FJ Cruiser.
Lastly, don't let the job stop you from doing it yourself. I double checked with my buds on the forum for any last minute advise and everything went as others have posted. The pay off is pretty sweet, I can't believe how much more power it has now...
Demello sliders
Demello rear bumper
Inchworm Lefty
ARB front air locker
Nitro 4.88 gears
Bud Built skids front to back
Super Swamper TrXus Mud Radial 255/85/16
Safari Snorkel
Train Hard, Rest Harder
TLCA # 17784
Mtbcoach is offline
Old 01-24-2008, 12:53 PM   #22 (permalink)
Admudistrator
Dragon's Avatar
Member Number: 2479
Those are the best install pics to date. Very nicely done. Welcome to Snorkelville
We are not at our best perched at the summit; we are climbers, at our best when the way is steep.
-John W. Gardner
Click
Dragon is offline
Old 01-24-2008, 01:00 PM   #23 (permalink)
oscarr's Avatar
Member Number: 7997
Thumbs up Re: Another snorkel installed...
Very nice.I think the snorkel is good if you use it depending on the terrain.Others just have it for looks.
ARB Bumper*OME Heavies*3" Skyjacker rear*Stock Steelies*Nittos Terras 295/70/17*Gobi Ladder*Cobra CB*AP Rock Sliders*Black Bezel*Real Wheels Light Bar*K&N Filter*Choped Body Mounts*Parrot Blue Tooth*Eliminated rear Sway Bar.
oscarr is online now
Old 01-24-2008, 01:25 PM   #24 (permalink)
volhoo's Avatar
Member Number: 5140
Nice...
volhoo is offline
Old 01-24-2008, 01:37 PM   #25 (permalink)
PRCruiser's Avatar
Member Number: 3524
Send a message via MSN to PRCruiser
Mtbcoach, I dont mind about it since you wrote an awesome detailed install. I see you could remove the whole fender liner. Excellent job there.
Having the snorkel is good in any ways..."you" never knows when its gonna be really needed.
PRCruiser is offline
Old 01-24-2008, 01:50 PM   #26 (permalink)
GTKrockeTT's Avatar
Member Number: 15581
i really need to stop clicking on these snorkel threads.
GTKrockeTT is offline
Old 01-24-2008, 01:57 PM   #27 (permalink)
Mtbcoach's Avatar
Member Number: 2433
Dragon previously said: View Post
volhoo previously said: View Post
Nice...
PRCruiser previously said: View Post
Thanks for the compliments. And, to be honest, I thought that this mod would be the last on my list of "need to have". But, the more I thought about the benefits of having a TRUE CAI (nothing like getting the air from 6' off the ground, in open air), the option of being able to turn the head around to avoid dust (we are in a serious drought and the trails are a mess with dust) let alone saving some issue like happened to a member that I don't recall, getting submerged on the wrong side, sucking in some water.
Most importantly, for posers like myself, it just looks cool...
Demello sliders
Demello rear bumper
Inchworm Lefty
Nitro 4.88 gears
Safari Snorkel
TLCA # 17784
Mtbcoach is offline
Old 01-24-2008, 02:19 PM   #28 (permalink)
PRCruiser's Avatar
Member Number: 3524
GTKrockeTT previously said: View Post
BUY THE SNORKEL BUY THE SNORKEL BUY THE SNORKEL BUY THE SNORKEL
Old 01-24-2008, 02:24 PM   #29 (permalink)
JAXTOY's Avatar
Member Number: 11799
I used a small file on the pillar holes, drilled them and then filed "notches" in four spots,(Corners) that way the inserts didn't rotate. Took a little more time but it worked really well. I also used small strips of window caulking around the base of the studs, (black sticking stuff that comes in strips) as the snorkle pulls against the body it spreads out and acks like small gaskets at each hole.
JAXTOY is offline
Old 01-24-2008, 03:27 PM   #30 (permalink)
Mtbcoach's Avatar
Member Number: 2433
JAXTOY previously said: View Post
I thought about doing the same thing, its a good idea. I thought it would be a good idea for all the holes but I was too lazy to dig it out of the garage. I was running short on time to get to work so I did the "normal" install. Hope I don't come to regret it with a leak of some sort down the road...
Demello sliders
Demello rear bumper
Inchworm Lefty
Nitro 4.88 gears
Safari Snorkel
TLCA # 17784
Mtbcoach is offline
