Old 12-04-2007, 08:47 PM   #1 (permalink)
PRCruiser's Avatar
Member Number: 3524
Send a message via MSN to PRCruiser
Another snorkel installed...
...but this one in Puerto Rico.
I picked it up last friday from the store.
Thanks to Dragon who was my advisor all the way. Everything was very easy but only one part that made me mad: The PITA fender liner; I took off like 127 clips and bolts from it and when I thought I finished removing everything, there were clips behind the bolts.
I could work without removing everything off. Thats the fender liner and the fender trim together.
I'm gonna keep that as a souvenir or use it as a bling bling to match my FJ.... What do you think?
Those holes were the easiest part of all the procedure. Obviously the template has to be perfect aligned.
Some touch up paint to cover the bare metal edges to prevent rust.
Applying blue loctite. Went to Home Depot and no one knew what was that...shame on them. Went to Pep Boys and there they were in different colors.
I removed the TRD CAI and you can see the Snorkel rubber tube.
I took the idea from Dragon by applying black silicone caulk to the gap between the rubber tube and the TRD CAI hole. I also used foam weather strip to pre-tight the area prior to apply the silicone.
Taaa-Daaa !!!!! And here is my snorkel. Now lets see how people react on the streets. Hahahahah !!!
Inside the cabin you don't see the snorkel so it wont be a problem for view blocking. This is one of the best things that came for the FJ, with less of 2 years on the market.
Once again, Thanks to Dragon for all the help he gave me.
Puerto Rico FJ Cruisers │ One Rule: Your Rules.
PRCruiser is offline
Old 12-04-2007, 09:05 PM   #2 (permalink)
matthart's Avatar
Member Number: 13048
Re: Another snorkel installed...
excellent job-
matthart is offline
Old 12-04-2007, 09:35 PM   #3 (permalink)
BigDouggieDoug's Avatar
Member Number: 10055
VERY NICE! First snorkel on an FJC in P.R..
Hoobastank still rules!
BigFJoy / '07 Sun Fusion FJC / modded & always itchin' for a trail run!
TLCA #16111
BigDouggieDoug is offline
Old 12-04-2007, 09:42 PM   #4 (permalink)
AceTechno's Avatar
Member Number: 4098
Nice write up and detailed pictures. Is there a big need for something like this in PR? Or is it more for looks?
PERFORMANCE: Airaid intake, Gibson Exhaust, Royal Purple Oils
LIFT KIT: Toytec/Donahoe Racing 3", Spidertrax spacers
EXTERIOR: Rear Tail lite Guards, GoodYear MT tires, AP Sliders, PIAA Headlights/dome lites, Fourtrex, Hi-lift
COLOR: Voodoo Blue 4x2
AUDIO: Dice iPod interface
INTERIOR: ScanGuage II, Ellis Design Black Handles & Battery Clamp. Littlelite 12" map light W/ Dimmer.
My Build: http://www.fjcruiserforums.com/forum...shockwave.html
AceTechno is offline
Old 12-04-2007, 09:56 PM   #5 (permalink)
PRCruiser's Avatar
Member Number: 3524
AceTechno previously said: View Post
Well, Is a perfect use in floods; here rains a lot and no matter how much rains there's always a huge flood somewhere on the roads. Also, I happen to go offroading with some friends of mine, so this will help me to avoid heavy dust and water from rivers crossing. we dont have those "off road open places" to go but we also have fun in our places. Also for better air intake temperature.
Puerto Rico FJ eventos <---- click to se pictures of events
Old 12-05-2007, 04:49 AM   #6 (permalink)
The Laughing Moderator
LandCruiserSteve's Avatar
Member Number: 8627
Great job and excellent write-up!!!!
Steve
The '07 Kiroi Hako
'59 FJ25
'78 FJ40
TLCA #6727
UFWDA
LandCruiserSteve is offline
Old 12-05-2007, 06:35 AM   #7 (permalink)
PRCruiser's Avatar
Member Number: 3524
Thank you all of you for the comments. In the begining I was kind of afraid to do the holes that later won't match with the bolts, but when i noticed they were big enough for error-margin I started making the big one first to "end the wail" with the 4¼" (108mm)hole saw, the continued the other holes with the step drill using masking tape to mark where was the measures to use (5/8) for the eight holes and (5/16) for the three upper screws. Everything was a perfect fit.
Old 12-05-2007, 06:42 AM   #8 (permalink)
Admudistrator
Dragon's Avatar
Member Number: 2479
It's a work of art and a thing of beauty. Very nice install and very nice write up. Rep for you
We are not at our best perched at the summit; we are climbers, at our best when the way is steep.
-John W. Gardner
Click
Dragon is offline
Old 12-06-2007, 05:04 AM   #9 (permalink)
PRCruiser's Avatar
Member Number: 3524
Thanks to you Bill.
Old 12-06-2007, 05:06 AM   #10 (permalink)
Admudistrator
Dragon's Avatar
Member Number: 2479
PRCruiser previously said: View Post
Thanks to you Bill.
Not at all. I just told you about my blunders
I'm glad you were able to do it yourself. It looks professionally done.
-John W. Gardner
Click
Dragon is offline
