Slightly different application 2014 4runner but same DVVTI motor. Since there are no reviews on this site yet I figure some of you may appreciate it.
Review:
Professional installation highly recommended. Hangers and rear bracket will need to be bent. Additionally, a heat shield bolt above the axle over pipe will need to be cut off, (you will notice the rattle after installation).
Very loud at WOT. There is a drone at 2500 rpm going 70 mph. This is a deal breaker for many of you. Below 2500 rpm the drone is barely noticeable. I may consider swapping a bigger magnaflow in at some point down the line... For now it's perfect!
On the butt Dyno there are definitely gains. Immediately noticed improvement in low end - which is the purpose of this equal length system. I will get this on the Dyno soon. Tried installing it immediately after the baseline stock run but the tuner shop couldn't do it. It needed a professional exhaust shop to make the minor adjustments necessary.
Overall very happy with the system.
-Performance? Exceeds expectations. Dyno pending.
-Sound? Loud at WOT. Low rumble at start up, idle, and cruising speed. No rasp, but there is a drone at 2500 rpm 70 MPH.
-Looks? In my opinion, best looking exhaust on the market period.
-Quality? Great. Due to the minor modifications required.
Vids:
https://youtu.be/QHcqLbeARqE
https://youtu.be/zLLLw7t803E
https://youtu.be/s2N39zbMXrs
https://youtu.be/EgJjPbRGkPY
Review:
Vids:
