Old 02-27-2008, 05:32 PM   #1 (permalink)
Member Number: 16009
quick question for guys who have installed the cyclone pre filter...
ok guys just ordered mine and wanted to know....if later I decide to put a snorkel on will it work with the cyclone prefilter??
survivorman is offline
Old 02-27-2008, 05:36 PM   #2 (permalink)
layonnn's Avatar
Member Number: 10006
Re: quick question for guys who have installed the cyclone pre filter...
I think it will work, you will just have to fab up something to make it work.
Layton
2007 FJ Cruiser 5AT 4x4
Voodoo Blue
"God forgives...rocks don't"
layonnn is offline
Old 02-27-2008, 05:57 PM   #3 (permalink)
fjpenguin's Avatar
Member Number: 12965
Yup, it does (I have that set up). I didn't follow the instructions for the ARB snorkel to the letter; they asked for you to cut the tip of the prefilter at the last inch or so as it goes into the fender. Problem is that the body of the prefilter is not nearly as strong as the original non-prefilter duct. So chances were that the hose clamp would collapse the wall of the tube as you tightened it to the snorkel rubber hose. So I reduced the hose instead, so it would fit to the tip of the prefilter, and then clamped that. I made sure that the lengths were such that the prefilter would firmly push against the rubber hose, so the clamp is almost unnecessary (make sure it takes some muscling to bolt the prefilter to the fender tho).
fjpenguin is offline
Old 02-27-2008, 05:59 PM   #4 (permalink)
FJpenguine.....hard to see your set up in my head....any pics you could post?
anyone else using the snorkel and cyclone filter??
