Old 02-28-2008, 06:58 PM   #1 (permalink)
ajstoy's Avatar
Member Number: 17560
more hp
have an 07 fj, 6" suspension, 35x12.5 ex at's from pro comp...gas milages not great, but now.....deff not great......aside from air intake, throttle body spacer, and exhaust, what can be done to get more out of it? the supercharger would be nice, but the price...not what im looking for....any suggestions would be much appreciated
ajstoy is offline
Old 02-28-2008, 07:03 PM   #2 (permalink)
billybongo63's Avatar
Member Number: 8894
Re: more hp
Horsepower cost $$$,
sounds like you got the basics, maybe spark plugs to iridium.
With 35's regearing to 4:56 would give you more "umph"
but figure to spend 2K.
Save for the supercharger, it's worth it!
Nice looking ride-Bill
'07 Moab Tested Pacific North West Proven.
Learning to crawl.........................but I ain't got knees.
billybongo63 is offline
Old 02-28-2008, 07:04 PM   #3 (permalink)
Fjamming's Avatar
Member Number: 6623
Re: more hp
Smaller tires will help you move around faster. Not sure if that conflics with your plans though...
Sandoo Blue FJ
SoCal Events Calendar
Fjamming is offline
Old 02-28-2008, 07:11 PM   #4 (permalink)
Disruptor's Avatar
Member Number: 10620
Send a message via AIM to Disruptor
Re: more hp
Get a chip like a unichip or the one from Underdog (then get it custom tuned), get headers, get a y-pipe... this should give you 2 to 3 more miles per gallon at the least and get a scan gauge help you keep your foot off the pedal as much.
Just a tip.. don't pay attention to the scan gauge's gas mileage reading when 4 wheeling.. lol.
Supercharger if you can afford it.. won't help much with mileage tho.
Disruptor is offline
Old 02-28-2008, 07:12 PM   #5 (permalink)
Disruptor's Avatar
Re: more hp
billybongo63 previously said: View Post
Would regearing it to that hurt or help your mileage?
Old 02-28-2008, 07:14 PM   #6 (permalink)
Fjamming's Avatar
Member Number: 6623
Re: more hp
Disruptor previously said: View Post
Help in most cases. You're lugging the engine otherwise.
Sandoo Blue FJ
Fjamming is offline
Old 02-28-2008, 07:26 PM   #7 (permalink)
ajstoy's Avatar
Re: more hp
thanx to all responding..has anyone used the unichip
ajstoy is offline
Old 02-29-2008, 06:54 AM   #8 (permalink)
Toledo FJ's Avatar
Member Number: 14676
Re: more hp
Yes I have the unichip custom tuned with the mods you see in my sig. I got my unichip from a forum member who got rid of his because he supercharged. I think this was a mistake on his part because the Unichip can be tuned for a forced induction system like a Supercharger, as well as any other mod you do to your rig. Custom tuning makes a really big diff. I think the tuner got like 18 more HP than the gains you'll see from a factory mapped Unichip (which isn't bad to begin with). I highly recommend the Unchip an even more highly recommend a custom tuning. It isn't cheap though... The unichip will cost about 6 or 7 hundred new and the custom tuning and install was about $700 more. But now I'm actually getting the power out of all my other mods that I wasn't getting before the chip. Here is a link to my Dynamometer charts:
Unichip Computer module
Keep in mind these numbers are for the HP and Torque at the wheels, not the engine. We need to find a stock, MT FJ to throw on the dyno for a baseline graph. Then he can calculate the power at the crank.
Toledo FJ is offline
Old 02-29-2008, 10:12 AM   #9 (permalink)
punch455's Avatar
Member Number: 17547
Send a message via AIM to punch455 Send a message via Yahoo to punch455
Re: more hp
It would hurt you mileage.. alot. Increasing the gear ratio to a 4.56:1, you're going to notice a considerable increase in engine RPM per MPH. In other words, let's say you're on the highway cruising at 60 MPH, and your engine RPMs are at 1800. If you increase the differential's gear ratio, you will notice that under the same driving circumstances, your new RPMs are at 3200. Your engine is working almost twice as hard to maintian the same vehicle speed. But you will DEFinitely notice an increase in acceleration too.
Also, if you're gonna swap your diff gears with new ratios, make sure to do the same to the front too if it's a 4WD.
WHERE ARE WE GOING... AND WHY AM I IN THIS HANDBASKET?
mmm bacon
punch455 is offline
Old 02-29-2008, 10:57 AM   #10 (permalink)
Fjamming's Avatar
Member Number: 6623
Re: more hp
punch455 previously said: View Post
A lower gear doesn't always hurt the gas mileage. Sometimes you're cruising at a speed that makes the engine work harder then it should so it either hunts or lowers a gear. If the gear is properly set, it'll stay at a more constant speed and maybe even lower rpm because it doesn't have to down shift. Imagine driving a manual with only 3rd and 5th gear, you'd like to be in 4, but you can't and have to either lug the engine in 5th or rev it in 3rd.
Sandoo Blue FJ
Fjamming is offline
