Old 03-06-2008, 10:19 AM   #31 (permalink)
BLUE TONKA's Avatar
Member Number: 11792
Send a message via AIM to BLUE TONKA
Re: Help! Swerve, ABS, VSC Off Lights came on!
SaltH2Odeprived previously said: View Post
Here a therory... you said after a "swerve" the lights came on. If you had the VSC cancelled with the switch, the computer received a failure from the VSC system because of the disconnect and it lit up all of the lights. Has anyone else with the VSC cancel mod had this problem?
You misread the post. The actual "swerve" light came on...I did not make the light come on by "swerving" or losing traction. The last time I used the switch was about 2 weeks ago.
Voodoo Blue FJ
BLUE TONKA is offline
Old 03-06-2008, 10:29 AM   #32 (permalink)
Member Number: 11817
Send a message via Yahoo to ziggzaggman
Generally speaking Autozone and PepBoys cant read ABS codes because those are manufacturer specific codes. Check engine lights (powertrain related) are standardized OBD II codes (with some exceptions) because of federal mandates. The feds dont mandate that the ABS and traction control be standardized, they may mandate that it have ABS, but not the troubleshooting portion.
ziggzaggman is offline
Old 03-06-2008, 11:10 AM   #33 (permalink)
BLUE TONKA's Avatar
I started up the car again, the 3 lights came back on. My OBD-II scanner still won't link up. What should I do?
EDIT: Got an appointment with the Mission Hills HAMER Toyota today at 1245. Hopefully they can help me out.
Voodoo Blue FJ
Old 03-06-2008, 12:27 PM   #34 (permalink)
Wheeler's Avatar
Member Number: 9216
Which wire did you tap into for the VSC disconnect switch? Just curious...
Wheeler is offline
Old 03-06-2008, 01:13 PM   #35 (permalink)
BLUE TONKA's Avatar
The purple one coming from the brake master cylinder. The connector has 2 wires...I think the other one is white?? This is off the top of my head.
The connecter is on the frontside if you are looking into the hood of the car from the headlighs. You have to pull the connector towards you to release it. I interrupted that wire with a switch previously.
Now it is soldered back and normal.
Voodoo Blue FJ
Old 03-06-2008, 03:09 PM   #36 (permalink)
Hopefully they will get you right. Keep us posted.
Tim
Old 03-06-2008, 03:35 PM   #37 (permalink)
BLUE TONKA's Avatar
I have an update!!!!!!
Service advisor called me back. Said it was a "Pressure Sending Unit". Said that "it sends oil to the brakes". I guess it went out on my FJ. They are getting the replacement part on Friday. My FJ will be ready by Friday night!!!
I am excited...everything will be good after this! Plus it's covered under warranty!!!!
Voodoo Blue FJ
Old 03-06-2008, 03:41 PM   #38 (permalink)
There you go i was rootin for ya. Glad to see the first visit didnt come back to haunt ya. Congrats.
Are you going to reinstall your switch?
Old 03-06-2008, 04:41 PM   #39 (permalink)
BLUE TONKA's Avatar
ziggzaggman previously said: View Post
Thanks zigg!! I appreciate any concern and help I got for getting this figured out! I took it to another dealer and everything is going to work out!
As for the switch...no. I never really used it. 4wd doesn't seem to have any traction control (VSC OFF) so if I want to get squirly on dirt, I will just be in 4wd. I need to fiberglass the holes in my lower dash plate now... That won't be bad though.
Voodoo Blue FJ
Old 03-06-2008, 05:35 PM   #40 (permalink)
erickc's Avatar
Member Number: 8698
Have you add an aftermarket intake or a setup of your own. I'm asking cause I was the ginny pig for Downey Offroad, on their Air Intake, and the lights also came on with mine. After reinstalling OEM air intake, lights turned off.
erickc is offline
